Joint Systems Posted October 17, 2019 Posted October 17, 2019 (edited) Neither jointsystem.us or jointsystems.org will all you to add a product to the cart. In debug mode received the error. Tried switching themes , and checkout mode did no good. Worked in prestashop before migration? Impossible to add the product to the cart.textStatus: 'parsererror'errorThrown: 'SyntaxError: Unexpected token < in JSON at position 0'responseText:Notice: A non well formed numeric value encountered in /home3/txmnbf6y/public_html/modules/upscarrier/upscarrier.php on line 1552Notice: A non well formed numeric value encountered in /home3/txmnbf6y/public_html/modules/upscarrier/upscarrier.php on line 1552Notice: A non well formed numeric value encountered in /home3/txmnbf6y/public_html/modules/upscarrier/upscarrier.php on line 1552Notice: A non well formed numeric value encountered in /home3/txmnbf6y/public_html/modules/upscarrier/upscarrier.php on line 1552Notice: A non well formed numeric value encountered in /home3/txmnbf6y/public_html/modules/upscarrier/upscarrier.php on line 1552Notice: A non well formed numeric value encountered in /home3/txmnbf6y/public_html/modules/upscarrier/upscarrier.php on line 1552{"products":[{"id":6271,"link":"https:\/\/jointsystems.org\/carburetor-parts\/6271-495606.html","quantity":1,"image":"https:\/\/jointsystems.org\/416-home_default\/4956062x.jpg","image_cart":"https:\/\/jointsystems.org\/416-cart_default\/4956062x.jpg","priceByLine":"$15.08","name":"495606","price":"$15.08","price_float":15.0800000000000000710542735760100185871124267578125,"idCombination":0,"idAddressDelivery":7,"is_gift":false,"hasAttributes":false,"hasCustomizedDatas":false,"customizedDatas":[]}],"discounts":[],"shippingCost":"$11.01","shippingCostFloat":11.0099999999999997868371792719699442386627197265625,"wrappingCost":"$0.00","nbTotalProducts":1,"total":"$26.09","productTotal":"$15.08","freeShipping":"$0.00","freeShippingFloat":0,"free_ship":false,"isVirtualCart":false,"hasError":false,"crossSelling":fals Edited October 17, 2019 by Joint Systems
wakabayashi Posted October 17, 2019 Posted October 17, 2019 What is upscarrier.php on these lines? The length of price_float and shippingCoasFloat are quite impressive... 1
lesley Posted October 18, 2019 Posted October 18, 2019 Do you have debug mode on? If so turn it off. 1
datakick Posted October 18, 2019 Posted October 18, 2019 You should upgrade to latest 1.1.0. That would actually solve this issue, as it contains new error handling code that does not emit notices or warnings to standard output Because you are experiencing so many issues, you should investigate what's wrong. Use core updater to detect modified files. Use Override check module to see what overrides you have installed. Use latest (unreleased) version of core updater 1.2.0 to find database differences, and possibly fix them, etc... 2
Joint Systems Posted October 19, 2019 Author Posted October 19, 2019 (edited) I upgraded several stores to 1.1 including jointsystems.us and creativesystemsusa.net, you still can't add anything to the cart. The upgrade itself went pretty smoothly and some of the stores actually work. Yes I did tale it out of the debug mode. Impossible to add the product to the cart. textStatus: 'error' errorThrown: 'Bad Request' responseText: Bad Request Your browser sent a request that this server could not understand. Size of a request header field exceeds server limit. Edited November 2, 2019 by Joint Systems addition of error message
Joint Systems Posted October 19, 2019 Author Posted October 19, 2019 I uploaded and installed the Niara theme and now you can add items to the cart but upon checkout still getting error from authorize AIM "Authorize.net returned a malformed response, aborted." Hostwinds says all thirty bees sever requirements are installed. Will authorize Pro work on thirty bees? The application requirement is fully satisfied as you can find from the below details. Please let us know if you require more assistance. [root@ded1246 ~]# /opt/cpanel/ea-php71/root/usr/bin/php -m bcmath calendar Core ctype curl date dom fileinfo filter ftp gd hash imap intl json libxml mbstring mcrypt memcached mysqli mysqlnd openssl pcntl pcre PDO pdo_mysql pdo_sqlite Phar posix readline Reflection session SimpleXML soap sockets SPL sqlite3 standard tokenizer wddx xml xmlreader xmlwriter xsl Zend OPcache zip zlib [Zend Modules] Zend OPcache [root@ded1246 ~]# /opt/cpanel/ea-php71/root/usr/bin/php -i | grep "allow_url_fopen|allow_url_include|post_max_size|max_input_vars|upload_max_filesize|expose_php" allow_url_fopen => On => On allow_url_include => Off => Off expose_php => Off => Off max_input_vars => 10000 => 10000 post_max_size => 32M => 32M upload_max_filesize => 25M => 25M [root@ded1246 ~]# httpd -M | grep "rewrite|auth_basic|security" auth_basic_module (shared) rewrite_module (shared) security2_module (shared) [root@ded1246 ~]# Alex Reynolds Tier 5 Technical Support 1-888-404-1279
Joint Systems Posted October 19, 2019 Author Posted October 19, 2019 CreativeSystemsusa was upgraded to 1.1x and after the Nira theme was applied you could use the shopping cart which already had items in it though they did not appear in 1.08. After the upgrade received this error: The following module(s) were not installed properly blocksupplier : Technical error: thirty bees could not install this module. ×Warning: You may have to regenerate images to fit with this new theme. Though at least 10 shipping choices were checked off but only two showed up? When attempting to check out CC choice did not appear though enabled. One apparent bug is when Amazon pay was added all the columns shifted to the right in the payment module country restrictions where check marks that were in the bank wire column now appeared in the check column. Checkmarks in the authorize aim were shifted to the bank wire. Amazon aim column was empty.
Joint Systems Posted October 19, 2019 Author Posted October 19, 2019 Rolled back to 1.1 stable and now shipping methods and CC check out now appear. still getting error from authorize AIM "Authorize.net returned a malformed response, aborted."
Joint Systems Posted October 19, 2019 Author Posted October 19, 2019 (edited) Error log from usengines.org thrown in /home/usenginescorp/public_html/usengine.org/modules/amzpayments/controllers/front/amzpayments.php on line 342 line 342 $physical_destination = $reference_details_result_wrapper->GetOrderReferenceDetailsResult->getOrderReferenceDetails() There is no error shown from authorize AIM module. Edited October 19, 2019 by Joint Systems additional info.
Joint Systems Posted November 4, 2019 Author Posted November 4, 2019 The Authorize.net payment error Malformed response was caused by curl being disabled on the server (for security reasons) once enabled it worked. Still getting the On google chrome on three stores but not on Microsoft edge. Anyone else experienced this or know what the solution is? Bad Request Your browser sent a request that this server could not understand. Size of a request header field exceeds server limit.
