oneall.com Module
Please could I have a bit of help here .. I have used this module for as long as I can remember.. It's been on the back burner for while now and am finally getting around to look into it.
I already have Facebook log in working correctly and logs me in fine.But it is not the case with Twitter, Everything works fine except when it comes to redirecting but to my page I get the error message below with a 500 page.
Now being nosy I read into on line 161 expect a 1, so I went there and found Tools::redirect ( ); so I tried making it (1 ); .. It got me past the 500 page but to a not found product page and it hadn't signed me in either.
So am hoping someone here can help if at all possible
Decoded exception
Too few arguments to function ToolsCore::redirect(), 0 passed in /home/edit out/public_html/modules/oneallsociallogin/controllers/front/register.php on line 161 and at least 1 expected
in file classes/Tools.php at line 218
Source file: classes/Tools.php
199:            }
200:
201:            $result .= sha1($entropy, true);
202:        }
203:
204:        return substr($result, 0, $length);
205:    }
206:
207:    /**
208:     * Redirect user to another page
209:     *
210:     * @param string       $url     Desired URL
211:     * @param string       $baseUri Base URI (optional)
212:     * @param Link         $link
213:     * @param string|array $headers A list of headers to send before redirection
214:     *
215:     * @since   1.0.0
216:     * @version 1.0.0 Initial version
217:     */
218:    public static function redirect($url, $baseUri = __PS_BASE_URI__, Link $link = null, $headers = null)
219:    {
220:        if (!$link) {
221:            $link = Context::getContext()->link;
222:        }
223:
224:        if (strpos($url, 'http://') === false && strpos($url, 'https://') === false && $link) {
225:            if (strpos($url, $baseUri) === 0) {
226:                $url = substr($url, strlen($baseUri));
227:            }
228:            if (strpos($url, 'index.php?controller=') !== false && strpos($url, 'index.php/') == 0) {
Thanks
You upgraded PHP recently, didn't you?
Tools::redirect() needs al least one argument, the address to redirect to. Module code apparently doesn't deliver that, so it's a bit unclear how this could ever work before.
Anyways, point of malfunction isn't in the cited code (Tools.php), but in the module in register.php line 161 or earlier.
Not 100% sure as it is automatic ... I tried to downgrade manually but it doesn't fix the issue.. I suppose it up to the dev of this module to upgrade it
Your hosting provider changed the php version on your *live site* automatically without your consent? That's just... well I'm speechless.
They on auto update.. I may have done that ... But it doesn't matter now as I am leaving this hosting as I can get VPS for 3 times less than with Shared
It is quite common for the hosting companies especially if all you are "hiring" is a cpanel and space for your website. Had this a few times with various hosts which is why I switched to VPS
Sigh
having issues with oneall again after I got it working with their help
Does this mean anything to any of you and how to fix.. It only happens with twitter log in , facebook is fine
` Decoded exception
Too few arguments to function ToolsCore::redirect(), 0 passed in /home/username/domains/mywebsite.co.uk/public_html/modules/oneallsociallogin/controllers/front/register.php on line 161 and at least 1 expected
in file classes/Tools.php at line 152
133: try {
134: return random_bytes($length);
135: } catch (Exception $e) {}
136: }
137:
138: return '';
139: }
140:
141: /**
142: * Redirect user to another page
143: *
144: * @param string $url Desired URL
145: * @param string $baseUri Base URI (optional)
146: * @param Link $link
147: * @param string|array $headers A list of headers to send before redirection
148: *
149: * @since 1.0.0
150: * @version 1.0.0 Initial version
151: */
152: public static function redirect($url, $baseUri = PS_BASE_URI, Link $link = null, $headers = null)
153: {
154: if (!$link) {
155: $link = Context::getContext()->link;
156: }
157:
158: if (strpos($url, 'http://') === false && strpos($url, 'https://') === false && $link) {
159: if (strpos($url, $baseUri) === 0) {
160: $url = substr($url, strlen($baseUri));
161: }
162: if (strpos($url, 'index.php?controller=') !== false && strpos($url, 'index.php/') == 0) {
Stack trace
1. modules/oneallsociallogin/controllers/front/register.php:161 source ToolsCore::redirect()
2. classes/controller/Controller.php:208 source OneAllSocialLoginRegisterModuleFrontController->initContent()
3. classes/controller/FrontController.php:255 source ControllerCore->run()
4. classes/Dispatcher.php:852 source FrontControllerCore->run()
5. ./index.php:33 source DispatcherCore->dispatch()
This is exactly the same problem as the one you have reported in the first post. The problem originated here:
I know , I thought it was exactly the same. I haven't changed anything on my website to cause it. I even reinstalled their corrected version from github.
Have you any idea as to what is causing the error
Well, obviously the 'corrected' version is not fixed :)
Could you please share github repo, I'll have a look
2 hours ago, datakick said:
Edit file controllers/front/register and replace line 161 with this.
Sorry for the late reply .tried that and still going to server error as that code is already there Tools::redirect();
please attach the modified register.php file
class OneAllSocialLoginRegisterModuleFrontController extends ModuleFrontController
    public $auth = false;
    public $ssl = true;
     * Assign template vars related to page content
    public function initContent()
        parent::initContent();
        global $smarty;
        // Restore back value.
        $back = Tools::getValue('back');
        if (!empty($back))
            $this->context->smarty->assign('back', Tools::safeOutput($back));
        // Did an error occur?
        $have_error = true;
        // The cookie is required to proceed.
        if (isset($this->context->cookie->oasl_data))
            // Extract the data.
            $data = json_decode($this->context->cookie->oasl_data, true);
            // Check data format.
            if (is_array($data))
                $have_error = false;
                // Submit Button Clicked
                if (Tools::isSubmit('submit'))
                    // Reset Errors.
                    $this->errors = array();
                    // Read fields.
                    $email = trim(Tools::getValue('oasl_email'));
                    $firstname = trim(Tools::getValue('oasl_firstname'));
                    $lastname = trim(Tools::getValue('oasl_lastname'));
                    $newsletter = intval(Tools::getValue('oasl_newsletter'));
                    // Make sure the firstname is not empty.
                    if (strlen($firstname) == 0)
                        $this->errors[] = Tools::displayError('Please enter your first name');
                    // Make sure the format of the firstname is correct.
                    elseif (!Validate::isName($firstname))
                        $this->errors[] = Tools::displayError('Please enter a valid first name');
                    // Make sure the lastname is not empty.
                    if (strlen($lastname) == 0)
                        $this->errors[] = Tools::displayError('Please enter your lastname');
                    // Make sure the format of the lastname is correct.
                    elseif (!Validate::isName($lastname))
                        $this->errors[] = Tools::displayError('Please enter a valid last name');
                    // Make sure the email address it is not empty.
                    if (strlen($email) == 0)
                        $this->errors[] = Tools::displayError('Please enter your email address');
                    // Make sure the format of the email address is correct.
                    elseif (!Validate::isEmail($email))
                        $this->errors[] = Tools::displayError('Please enter a valid email address');
                    // Make sure the email address is not already taken.
                    elseif (oneall_social_login_tools::get_id_customer_for_email_address($email) !== false)
                        $this->errors[] = Tools::displayError('This email address is already taken');
                    // We are good to go.
                    if (count($this->errors) == 0)
                        // Store the manually entered email fields.
                        $data['user_email'] = strtolower($email);
                        $data['user_first_name'] = ucwords(strtolower($firstname));
                        $data['user_last_name'] = ucwords(strtolower($lastname));
                        $data['user_newsletter'] = ($newsletter == 1 ? 1 : 0);
                        // Email flags.
                        $send_email_to_admin = ((Configuration::get('OASL_EMAIL_ADMIN_DISABLE') != 1) ? true : false);
                        $send_email_to_customer = ((Configuration::get('OASL_EMAIL_CUSTOMER_DISABLE') != 1) ? true : false);
                        // Create a new account.
                        $id_customer = oneall_social_login_tools::create_customer_from_data($data, $send_email_to_admin, $send_email_to_customer);
                        // Login the customer.
                        if (!empty($id_customer) and oneall_social_login_tools::login_customer($id_customer))
                            // Remove the data
                            unset($this->context->cookie->oasl_data);
                            // A refresh is required to update the page
                            $back = trim(Tools::getValue('back'));
                            $back = (!empty($back) ? $back : oneall_social_login_tools::get_current_url());
                            Tools::redirect($back);
                // First call of the page.
                else
                    $smarty->assign('oasl_populate', 1);
                    $smarty->assign('oasl_email', (isset($data['user_email']) ? $data['user_email'] : ''));
                    $smarty->assign('oasl_first_name', (isset($data['user_first_name']) ? $data['user_first_name'] : ''));
                    $smarty->assign('oasl_last_name', (isset($data['user_last_name']) ? $data['user_last_name'] : ''));
                    $smarty->assign('oasl_newsletter', 1);
                // Assign template vars.
                $smarty->assign('identity_provider', $data['identity_provider']);
                $smarty->assign('oasl_register', $this->context->link->getModuleLink('oneallsociallogin', 'register'));
                // Show our template.
                $this->setTemplate('oneallsociallogin_register.tpl');
        // We could not extract the data.
        if ($have_error)
          Tools::redirect();
@AndyC, you didn't replace the like 161 with the new content. The file should end like this:
        if ($have_error)
Don't know where my last post went ..
But this is what it looks like now .Am still getting a server error
        if ($have_error)
        if ($have_error)
It can't be the same error. Even if the $back variable contain null, it is still value that is being passed to the Tools::redirect method. So it's not possible for this to throw Too few arguments to function error.
OK downloaded the error and decrypted.. But yes it is different now
 Decoded exception
syntax error, unexpected end of file
in file modules/oneallsociallogin/controllers/front/register.php at line 164
Source file: modules/oneallsociallogin/controllers/front/register.php
145:                    $smarty->assign('oasl_last_name', (isset($data['user_last_name']) ? $data['user_last_name'] : ''));
146:                    $smarty->assign('oasl_newsletter', 1);
147:                }
148:
149:                // Assign template vars.
150:                $smarty->assign('identity_provider', $data['identity_provider']);
151:                $smarty->assign('oasl_register', $this->context->link->getModuleLink('oneallsociallogin', 'register'));
152:
153:                // Show our template.
154:                $this->setTemplate('oneallsociallogin_register.tpl');
155:            }
156:        }
157:
158:        // We could not extract the data.
159:        if ($have_error)
160:        {
161:            $back = trim(Tools::getValue('back'));
162:            $back = (!empty($back) ? $back : oneall_social_login_tools::get_current_url());
163:            Tools::redirect($back);
164:        }
Stack trace
1. ./index.php:33 source DispatcherCore->dispatch()
First of all, you should enable debug mode when you are debugging the site 🙂 You can use my 'Advanced debug mode' module that will make sure that you will always use debug mode, yet your customers will use normal mode.
Anyway, back to the error at hand - your file is missing ending brackets }
Take original file, find line 161:
          Tools::redirect();
and replace it with these three lines:
Don't change anything else.
OK have installed your module .Did as asked ,now getting
Too few arguments to function ToolsCore::redirect(), 0 passed in /home/u564696606/domains/pewterworld.co.uk/public_html/modules/oneallsociallogin/controllers/front/register.php on line 161 and at least 1 expected
133:            try {
136:        }
137:
138:        return '';
139:    }
140:
141:    /**
143:     *
148:     *
149:     * @since   1.0.0
151:     */
152:    public static function redirect($url, $baseUri = __PS_BASE_URI__, Link $link = null, $headers = null)
153:    {
154:        if (!$link) {
156:        }
157:
161:            }
Stack trace
It now looks like this
        if ($have_error)
Ahhh OK turned off cache on server..
It goes though the motions now and comes back to the main screen (no more server error) .But doesn't log me in. If I use your debug mode there is no error shown
