I had a customer point out to me one of the catagories is linking back to the home page and not sure how to fix it or what the actual problem is
all the other catagories work flawlessly, I tried deleting the catagory and rebuilding it  and associating the products to the catagory and it does the same
in the screen shot you will see bottom left while mouse over it appears to be pointing to the correct address, i have done all the normal cleared cache  and cleared cache on local pc and im stuck
Url is https://www.thepelletguys.com/match-tackle
In Degug Mode I get this when I try to edit the sub catagory
Edited by The Pellet Guy
Its the Tools sub catergory bottom right that is throwing the problem  i can't get my head around it  I have checked and I have set it up exactly the same,   when you mouse over  the address its pointing to is correct but resolves to the home page
I renamed it tools and Gadgets and it works
I made another catergory  Tools2  added the products and it worked so i deleted the non working Catergory  thinking I could cheat the stystem and rename tools2  to just Tools  and as soon as I renamed to Tools  clicking the imaged resolved to the home page,  renaming the Catergory to Tools & Gadgets  worked.
Now thats what you call a ghost in the machine
Expand
It seems like a rewrite to me. Is there anything referring to 'tools' in your .htaccess?
Check out SEO and URLs and regenerate your .htaccess.
Try renaming again to tools2, and accessing to tools. If it redirects you to homepage it has nothing to do with your category, but with your web server treating 'tools' in a special way.
I tried the above and same result it resolves to Home page  switched back to tools and gadgets which in all hoesty isnt a problem and it worked as it should,  there is something going on with the word tools,  as long as it doesnt throw any errors down the line  I can live with a name change
Is there perhaps another category or a product with the same name? This would result in the same URL. There's a module 'Duplicate URLs', which detects such issues.
  • 1 year later...
