30knees Posted November 5, 2020 Posted November 5, 2020 (edited) Update: This is a Panda theme issue. Problem: I have a product with a combination. The price for 1x is 10 incl. taxes. This is displayed correctly. Starting at 5x the price is set as 9 incl. taxes. It should show 9 incl. taxes (which would be 8 excl. taxes). However, it shows 8 excl. taxes. It's misleading for customers, understandably. Edited November 9, 2020 by 30knees Update
0 datakick Posted November 5, 2020 Posted November 5, 2020 I can't reproduce this issue. Could you please provide some screenshots, both from the admin and frontend? Note that this might be theme issue
0 30knees Posted November 7, 2020 Author Posted November 7, 2020 Thank you for helping out. Admin specific price: Combination standard price: Frontend price standard: Front end price with volume discount 2x: Shopping cart price for volume discount 2x (this is your Chex module): 17.02 / 2 is 8.51, which is the displayed volume price above plus tax.
0 datakick Posted November 7, 2020 Posted November 7, 2020 I've re-tested with your numbers and it works fine for me. I guess this is either theme issue, or you are using old thirtybees version. Â
0 30knees Posted November 8, 2020 Author Posted November 8, 2020 Thank you, datakick. I'm using the Panda theme. @JonnyAre you aware of any issues as described above? I have version 1.5.5.
0 30knees Posted November 9, 2020 Author Posted November 9, 2020 Yes, it is the theme. I tested with the community template and it works perfectly fine there.Â
0 datakick Posted November 12, 2020 Posted November 12, 2020 Try to upload js/product.js from community or niara theme to panda to see if it fixes the problem. Back up the original file, of course
0 30knees Posted November 12, 2020 Author Posted November 12, 2020 Unfortunately, it didn't work. It also prevented the product photo from displaying when I did that. I used the community theme to do so. Thank you for the tip, though!
0 haylau Posted November 12, 2020 Posted November 12, 2020 Have you reported this directly on the sunnytoo forum?
0 datakick Posted November 13, 2020 Posted November 13, 2020 This is indeed bug in product.js file, function updateDiscountTable. Change it from: function updateDiscountTable(newPrice) { $('#quantityDiscount').find('tbody tr').each(function() { var type = $(this).data('discount-type'); var discount = $(this).data('discount'); var quantity = $(this).data('discount-quantity'); var discountedPrice; var discountUpTo; if (type == 'percentage') { discountedPrice = newPrice * (1 - discount / 100); discountUpTo = newPrice * (discount / 100) * quantity; } else if (type == 'amount') { discountedPrice = newPrice - discount; discountUpTo = discount * quantity; } if (displayDiscountPrice != 0 && discountedPrice != 0) { $(this).attr('data-real-discount-value', formatCurrency(discountedPrice * currencyRate, currencyFormat, currencySign, currencyBlank)); $(this).children('td').eq(1).text(formatCurrency(discountedPrice * currencyRate, currencyFormat, currencySign, currencyBlank)); } $(this).children('td').eq(2).text(upToTxt + ' ' + formatCurrency(discountUpTo * currencyRate, currencyFormat, currencySign, currencyBlank)); // $(this).attr('data-real-discount-value', formatCurrency(discountedPrice * currencyRate, currencyFormat, currencySign, currencyBlank)); }); } to function updateDiscountTable(newPrice) { $('#quantityDiscount').find('tbody tr').each(function() { var type = $(this).data('discount-type'); var discount = $(this).data('discount'); var quantity = $(this).data('discount-quantity'); var discountedPrice; var discountUpTo; if (type == 'percentage') { discountedPrice = newPrice * (1 - discount / 100); discountUpTo = newPrice * (discount / 100) * quantity; } else if (type == 'amount') { discountedPrice = newPrice - discount; discountUpTo = discount * quantity; } if (displayDiscountPrice != 0 && discountedPrice != 0) { $(this).children('td').eq(1).text(formatCurrency(discountedPrice, currencyFormat, currencySign, currencyBlank)); } $(this).attr('data-real-discount-value', formatCurrency(discountedPrice, currencyFormat, currencySign, currencyBlank)); $(this).children('td').eq(2).text(upToTxt + ' ' + formatCurrency(discountUpTo, currencyFormat, currencySign, currencyBlank)); }); }  In community theme / niara this was fixed by commit https://github.com/thirtybees/niara/commit/e70102d1816aa1af03c2d8ff2b9d446146aa3ff9  1
0 30knees Posted November 13, 2020 Author Posted November 13, 2020 16 hours ago, haylau said: Have you reported this directly on the sunnytoo forum? They changed their login method and I'm waiting for access. I may need to send a follow-up if I don't hear back by end of next week.Â
0 30knees Posted November 13, 2020 Author Posted November 13, 2020 2 hours ago, datakick said: This is indeed bug in product.js file, function updateDiscountTable. (SNIP) Change it from:In community theme / niara this was fixed by commit https://github.com/thirtybees/niara/commit/e70102d1816aa1af03c2d8ff2b9d446146aa3ff9  Thank you so much, that's so nice of you to check! Thank you so much. 🙂
30knees
Problem:
It's misleading for customers, understandably.Â
Edited by 30kneesUpdate
11 answers to this question
