Havouza Posted November 21, 2020 Posted November 21, 2020 Hi! After successfully cloned our shop and made them with its own categories and customers its only one thing left. Take away order and customers from the nuw one to be able to start from scratch There is a TB mudule for it but it seems that it does not work. I press the button but noything happens And thoughts Anders
AndyC Posted November 21, 2020 Posted November 21, 2020 Try this free module , that works quite well https://mypresta.eu/modules/administration-tools/delete-orders-free.html To delete customers have you tried the bulk delete at the bottom of page
Havouza Posted November 22, 2020 Author Posted November 22, 2020 Hi. I have that module. But if there is a TB module already installed, I thought is should work
wakabayashi Posted November 22, 2020 Posted November 22, 2020 I am not sure, but there exits a cleaner module for tb/ps. After a clean installation there are always a few orders. With the cleaner module you can remove it. Maybe it works for you too. Or is this the module you are talking about?
Havouza Posted November 22, 2020 Author Posted November 22, 2020 Yes, thats the module. . Perhaps the demo orders and customers are id special and this id is what is taken away. But for normal orders and customers it does not work. Stupid in that case
datakick Posted November 23, 2020 Posted November 23, 2020 19 hours ago, Havouza said: Yes, thats the module. . Perhaps the demo orders and customers are id special and this id is what is taken away. But for normal orders and customers it does not work. Stupid in that case No, it works for all orders. If it does not work for you, then there is probably some permissions issue
Havouza Posted November 23, 2020 Author Posted November 23, 2020 Well the db user has all rights so I have hard ti see what can be a permission problem. But I just used sql to delete them and all seems to work. Its a one time thing anyway
datakick Posted November 23, 2020 Posted November 23, 2020 11 minutes ago, Havouza said: Well the db user has all rights so I have hard ti see what can be a permission problem. But I just used sql to delete them and all seems to work. Its a one time thing anyway The fact that the module does not work is a pretty red flag. There is something fishy there. If I were you I would try to figure out what it was, otherwise it will come back to haunt you later.
Havouza Posted November 23, 2020 Author Posted November 23, 2020 Well the shop has worked without many flaws since before TB was forked, through all TB updates and still do. This split into two shops is a one time event that worked well also. If we experience any problems related to this we solve them when they occur. Other errors we will ofc get, admin caused or TB caused
