Products and Sales list in Admin
Now that I have quite a few orders on the go.. How does everyone find a single particular order without having to open every order to find it in Admin/Sales
Is there a way to add the products they bought to the order so you can see it at a glance
Not sure what you mean. Can you give an example.
We bulk print every invoice order in the morning with a status of “payment accepted” Then in the order list page we filter for all ‘payment  accepted’ and then bulk change to “processing”
I don't have to print. I just use admin and go by the Status
If I want to find a particular order I have to always open every 1 to see if it is the 1 I want
Which order contains what
Well the system can't be phycic, and know what you specifically want to find,  nor can we 🙂
So more specifically. What are you trying to find a specifc order for. When you say you want to find a particialr order - why? what for ? what is it specifically you are wanting to find? How do you know what order you are looking for?
exactly.
Trying to find out which customer ordered a glass with engraving at a glance.. It would be much easier if it looked like this
Then you can click on the correct order as is now visible
Great, that is very clear (glass - get it? See what I did there - ahem, cut back on the xmas beverages - lol)
A (very) quick google suggests not at all easy. You need to "join" tables together in the code (or use overirdes), and add complexities such as if a customer orders more than 1 item it could get very untidy.
Some ideas: https://www.google.com/search?newwindow=1&biw=1517&bih=631&sxsrf=ALeKk00mN8M3VF9WCUgIoWrotE6rRvCB6w%3A1607695348010&ei=9HvTX9wXwo_yAr_ytegG&q=+add+extra+columns+to+order+list+prestashop+module&oq=+add+extra+columns+to+order+list+prestashop+module&gs_lcp=CgZwc3ktYWIQAzIFCCEQoAE6BAghEBU6BwghEAoQoAFQxuURWKOEEmDPhRJoAHAAeACAAcUBiAHKCJIBAzMuNpgBAKABAaoBB2d3cy13aXrAAQE&sclient=psy-ab&ved=0ahUKEwjc4f_wi8btAhXCh1wKHT95DW04ChDh1QMIDQ&uact=5
lol .. Yeah I also saw it's not that easy ... Which is why I was hoping there was a module out there.  In Zencart it used to put a picture of the products against the order which was great
Not special lol... Most of my products are dropshipped, so just use the status to follow orders as to where they are and what's happening
Wow.Yes that's actually perfect and what I am after.. Thank you.
Now just gotta figure it out how to do it..
Have tried but keep getting a page 500 error
@colorful-ant
Thank you , works perfectly now.. Really appreciate the time you have taken to get it working.
Should be part of the core features as well I think
