led24ee
Everything posted by led24ee
  1. It's working. Thanks.
  2. Hi, About this slider option. This slider is available only built-in possibilities like price or weight. But this i really annoying that You can't use this with other possibilities. So if you offer some items by length, then it is really good to use slider. At the moment you can use "click" type solution, but this is also annoying because filter runs automatically after every click and if there is many items then it is better to leave then scroll every time back and find another option. So is there option to put button "Run" or "Do" or something similar, then You can click on all possibilities and when you are done THEN filter is running ?
  3. led24ee
    logged out
    Try to delete all cookies.
  4. That's the best answer for many question so far.
  5. Thanks. Now You can also see why there isn't much users.
  6. You don't really understand ? There is one question and it's about future. More than year. And there is ZERO useful answer to this short question. Because "wait and You will see" is not really an answer.
  7. There's module, Order IP Address Verification. Results are visible on SQL database for every cart. This table stays even if You delete cart.
  8. Can You give example of modern function ? Years ago there was at least talk about advanced stock management. Is there any result ?
  9. There isn't easy way. I have asked such functionality many years before TB. Zero possibility so far. I'm not code writer, but from answer I understand that for this functionality there is need for too many things to modify. And nobody will do it, because most shops can live without this.
  10. I still don't get it very well. In TB there is also possibility for "related products" where You can directly "bound" the base plate "or plates" for specific ubolt. No need to search anything. But maybe my english is not good enough to understand.
  11. How is this different from combinations ?
  12. For missing images You can try Consistency Check.
  13. I have similar problems and I need to close not only tab but whole browser. There is too much data in temp catalog. Many people never close tab or browser (doesn't matter what they use, mobile, PC, laptop, etc) and then all this data is stored and this just takes huge amount of memory and does nothing useful. Some users have more tabs and apps open than they have hair. But I have no idea is this related at the moment.
  14. Looks like I'm missing something.
  15. There is need for custom or extra field for transport. I have offered possibility for transport "I'll specify later" but I can't enter price, because there isn't price. If I put "free" then I can't explain to customer that this free isn't actually free. Or maybe there is possibility that I haven't find yet ?
  16. There is need to add captcha also to newsletter subscription.
  17. With tax this price is already 113% and not 100%. And then 100% is 17.699115 .... (20 / 1.13). And don't worry. This mistake is very common. It is important to understand percentage calculations.
  18. There could be place for separate e-mail address for invoice. Also I have need to sell items less than 1 unit. For example I have base price for one meter, but sometimes I need to sell half meter.
  19. Well, for You this is good, but for other this is pretty useless until there is more info what was reason and how to avoid this situation.
  20. This error500 is in BO or FO or both ?
  21. I only know that google has made some changes in search results.
  22. robots.txt can be edit in Preferences -> SEO & URLs
  23. quicksearch dropdown results can have pictures. This is also from NemoPS. If client send message and to need to answer then inside TB i haven't found possibility to add pictures. I need these sometimes for better answer. When You add new client manually, then there are flelds for address. And later you need to input address for this client again. Is this some really weird thing or I'm doing something wrong ? I have situation when multiple client using the same email. And this is really PITA. Is there any possibility to identify client with email and name too ? I mean this is only for backoffice. Simplest solution is just possibility to put another field for next name. In FO this is porbably mother for all fu**ups. When making order in BO then there can be possibility to change price. At the moment you can put in price field something but system don't use this later and changes this to actual price. This change can be done with some warnings where is actual price and then some calculations based on price what You put in field. For example You can see discount in percent and in numbers, and also some math with wholesale price.
  24. I understand that this is completely separated package with contains TB. So when You run TB updater then answer is no because TB updater has no idea where this package is. But maybe I'm wrong
  25. There are many thousand traders in EU who are not selling to UK. So don't put "and" there.
