zen
Everything posted by zen
  1. OK, I see what you are talking about now.. I will add something with the same idea, but not exactly like that as this bar consume too much space on the bottom screen of the mobile. I think that the burger menu icon that is on top will open the side control menu/panel with all infos and actions in it.
  2. I'll be happy to integrate it, what function are you talking about exactly, do you have an exemple ?
  3. This is nice but it needs to be integrate into Thirtybees templating system, that's what I am doing right now on this topic : help me to finish it.. and you'll get the free source also.
  4. I just added the block currencies and block language on the footer, I had to make new modules for that.
  5. some modules just don't follow basic rules, but i believe they will still work with just a little pinch of css (as I had to keep Jquery with this theme version, getting rif of it is next step, but it's a big one). It will take the time needed => the earlier we start and the faster it will be done 🙂 I have a lot of hope and good faith in TB !
  6. The task will also be to make all modules working with Boostrap 5 by modifying the TPL files or at least with some added/modified css. If not possible I can also provide a new version / copy of the official module but that works with this theme. If you have some module in mind.. don't hesitate to tell me which one so I can prepare the tpl and css for this module in the theme
  7. Bonjour à tous, je travaille actuellement sur un thème basé sur le framework CSS Bootstrap 5 pour le CMS ThirtyBees et j'aimerais le partager avec la communauté au moins pour la version de base. J'ai besoin de votre aide pour pouvoir le terminer. Merci de signaler ici les bonnes et les mauvaises choses à propos du thème, afin que je puisse le réparer ou les améliorer et demander de nouveaux tests avant de le mettre sur Github proprement. Et voici le back office admin qui peut vous permettre d'utiliser le module ThemeMaster, qui vous aidera à personnaliser votre propre design, c'est la toute première version et n'hésitez pas à demander les choses à gérer depuis ce module : https://cisero.zengraph.com/admin007 utilisateur : [email protected] pass : demodemo Alors commençons, j'espère le finir avant janvier 2022, cela dépend aussi de vos retours. Voici le post original en anglais, pour le bug report ça se passera là :
  8. Hello all, I am curently working on a Bootstrap 5 theme for Thirtybees and would like to share it with the community at least for the basic version. I need your help in order to finish it, while completing this task I'd like that you can report here the good and the bad things about the theme, so i can fix it or improve it and ask for new testing before I put it on github and manage it on that platform, as it's way more easy for me to do it here for start. And here is the admin back office that can let you use the ThemeMaster module, that will help you to customize your own design, it's very first version and don't hesitate to ask for things to manage from this module : https://cisero.zengraph.com/admin007/ user: [email protected] pass: demodemo So let's start it, I hope to finish it before january 2022, it also depends on your returns. Here is the ARCHIVE to download on a zip format, please report bugs and improvement ! Also here is the GITHUB link : https://github.com/Zengraph/cisero Cisero_theme_TB.zip
  9. effectivement si le client n'est pas identifié, impossible de définir le prix de livraison de façon intelligente.. par contre on peut quand même faire en sorte que ça affiche quelque chose de plus intéressant.
  10. Merci Tanguy pour ton post et c'est une excellente question, et finalement c'est quoi le souci ? histoire de le fixer une bonne fois pour toutes.
  11. Thank you for keeping us updated 🙂 Best regards.
  12. May I try to help you bhtoys ? Contact me in private, let's see how to fix that 🙂
  13. For Prestashop 1.7 the best template available for free for custom needs may be this one : https://github.com/prestarocket-agence/classic-rocket it's only using : Twitter Bootstrap 4.4.x It's time to overpass this and go Frameworkless or boostrap 5 compatible, what do you think ?
  14. Boostrap Currently v5.1.1 without Jquery and different shorcode for classes, so It is not possible to use it as well. What about Boostrap 4 ? also not really easy to make modules compatibles with it without rewriting their tpl section. So we can stick only to Jquery and Boostrap 3 ? I hope not.. what are the solutions, a transition version or a breaking one ? If we keep on like this, TB is not going anywhere, I believe we need to get rid of Jquery first, that will need some work on many modules but it's for the best and a brighter future.
  15. the main thing to focus on is where the servers are, and how there are connected, wich performances are delivered.. etc
  16. You should use a US based hoster, problem is to choose one, the offer is so wide.
  17. Great to know that, let's keep the good work flow ! For infos, I still use TB everyday mostly on b2b websites 🙂, some are still on 1.1.0 version and works perfectly.
  18. OK, I understand now... thank yaniv14, it was so obvious, First you need to create it on Google website, I thought he couln't find the place to fill his keys 😞
  19. What do you want exactly from your hosting, what budget are you willing to pay ? Where are your customers ?
  20. when you say to another shop.. what does it mean.. another installation of TB ?
  21. there is a problem then.. because after you install this module, you should go to configuration and ther will be places to fill the public and private keys.
  22. Have you try this free tool ? https://www.red-gate.com/products/mysql/mysql-compare/ I used it several times when needed and it does the job very well !
  23. No, it was only a small storm ending up with nothing. Now even more questions and doubts about how and when having a new theme.
