Issue with 1.08 and Warehouse theme
After update to 1.08, my css multi-line text boxes from warehouse modules no longer work. They are input in format:
.header-container.inline-header.alt-cart {
    box-shadow: 0px 0px 5px #000000 !important;
After clicking save button, they are reformatted to:
.header-container.inline-header.alt-cart {\r\n    box-shadow: 0px 0px 5px #000000 !important;\r\n}
Also, when I attempt to use their content creator module, I get 500 errors on save.
I did not get either error in 1.07. Warehouse theme has not changed.
9 answers to this question
I had this issue as well.
Had to edit global.css to fix my issues instead.
Seems the thread I made about it was deleted though.
Edited by Purity
Yes, on the old forum.
According to my developer, definitely TB related, and something done with the 1.0.8 update, as I was on 1.0.7 before.
He said the below text, and told me to inquire about the change, but I'm not sure what the exact issue is at this point in time.
He might help me diagnose the exact issue at a later date, but he thought the developers would know what the problem was.
I did not receive a response after I posted this on my other thread, but I think everybody was busy with the forum change.
Quote
The core (TB) API changed it's API
likely this module isn't specifying that it doesn't want 'blah' escaped
And they required later that modules do that
They'll likely be able to tell you deeper info about what to change
that you should relay to me
and we can get it done
we can also just look in the module and figure it out
but I'm lazy
and let's be honest
it's really easy to just update global.css
Edited by Purity
typo
Hmm.
Perhaps I was not clear enough in my last post.
The workaround we used was to simply bypass the css boxes in the warehouse modules and add the css code directly to global.css
If I ever have him look at the module to find out more, I will post about it, but we might just keep adding the css code directly...he seems to think it's easier. lol
The issue actually ended up removing my entire menu on, specifically, mobile, for 2 weeks without me knowing due to how I had my menu css setup.
Edited by Purity
2 hours ago, datakick said:
If you are not willing to wait for 1.0.9, then you can try to apply the fix from this commit (or simply copy the newest version of Configuration.php file to your tb classed directory). That should fix this problem.
I haven't tried this yet but it's great to see a fix available.
Thank you.
