I am a bit puzzled about the product dimension, which you can define under Shippment in the BO. In switzerland we do this like that: "Länge * Breite * Höhe". Translated into english this would be "Length * Width * Height". A possible alternative would probably be "Length * Width * Depth".
But in the backoffice it's like: "Width * Height * Depth". Does this make any sense in GB/USA? From my german perspective "Height" and "Depth" are the same, but length is missing 🤨
I know of course that the order of mulitplication doesn't matter. But I wan't to display this information in the FrontOffice. So I want to use them correctly.
In TB depth is like length, at least I use it like this. I have no idea why this is so. Looks like this is similar to "lift" and "elevator" thing.
I never had a problem with this, nor to be confusing 🙂
From my point of view I see it like this - Wow your TV is so Wide, what's total depth of it with stand mounted? 🙂
BO Width = Lenght of the package
BO Height = Height of the package
BO Depth = Width of the package
Edited by toplakd
