Indiegogo ElasticSearch project
vincentdenkspel
  • Replies 172
  • Created
  • Last Reply
Top Posters In This Topic
  • 2 weeks later...
I just tried to install the beta on my test site, I got the following error.. [PrestaShop] Fatal error in module file :/var/www/vhosts/-------/-----------/modules/elasticsearch/elasticsearch.php: Cannot use isset() on the result of a function call (you can use "null !== func()" instead)
I commented out with --- important url
Just tried the new version on cloudways. elasticsearch 5.4 enabled. Does not seem to work. The problem is that it cannot save Indexing and Search to on.
I turned all fields in Indexing and Search to On. Then click on save and stay. Then I return to dashboard. The fields in indexing and search are back to Off.
Hence, the elasticsearch does not work.
Thanks.
I'm back into website dev mode again, have a test site running with ~3000 products on it. I have a couple more API things to iron out and then I will start monkeying around with the new ES module! Very much looking forward to trying it out. :)
Are there any areas in particular that you would like tested?
