Feature Request Time!
wakabayashi replied to Messenger Bee's topic in Announcements about thirty bees
I believe there is some misunderstanding. Are you aware, that you can set the BO design in BO? Just go to the employees settings. -
Isn't that, what TB did the last years? There were no huge changes. Technical Stack is almost the same as in PS 1.6. Acutally I see it the other way. I wish we could drive the project more forward, since ecommerce changes fastly and is very competitive. -
It's hard for me to understand, what you are talking about? Do I get right, that you don't want to update to 1.3 for some reason? -
This is very likely to be a spamming account. Often they edit their post a few days after and try to place a backlink to their website. It's always very supicious if somebody has less than 10 posts and answers to an old post. Especially if it's about SEO ^^
Error 500 mit Silbersaiten Modul
wakabayashi replied to Chris Seiler's topic in Deutsches Forum - Generelle Fragen
Der Bug wurde noch nicht gefixt. Er ist noch offen. Mir ist auch nicht ganz klar, wo der Bug genau liegt. Bei mir funktioniert ein sehr ähnlicher Code. Datakick scheint da, aber eine bessere Ahnung davon zu haben. -
Du hast oben einen wichtigen Teil der Fehlermeldung abgeschnitten. Das Problem liegt irgendwie mit der Url Rewrite zusammen. -
@datakick Thx for all the explanations. What I haven't got yet: what is the work queue technically? Is it actually a well organized/structured cronjob? Cause what you describe, are we doing over cronjobs. Instead of doing a task, we just save it to a "cronjob table" and every minute the cronjob is checking, if he has some tasks to do ☺️ That's why I wonder, if it's actually pretty much the same or if it's not cronjob related!?
ASM & Custom ERP 🤷♂️ Our stocks in ASM are correct for 99% of our products. Then we calculate expected sales for the next period (based on sales and some other factors). The system then generates a proposal supply order, which is adjusted by a human worker. The whole process was inspired by: https://www.inventory-planner.com/
- 1 reply
- 1
I have now started, to develop a front office module, thats implements a "framework" for thirty bees. Technically this is not super complex and it works already quite good. But if this should become the new standard in thirty bees, I need some help. We will need to design default styles. Who is ready to help on this project? What you knowledge do you need? (very) good knowledge of CSS Been able to work on tpl files. So you need HTML knowledge and basic knowledge in how to use {$any_random_variable}. Knowledge in JS doesn't harm either, but a lot of elements/components don't need JS at all. Of course I would give more informations in detail, what has to be done. Note: this is not a 20 minutes job. I expect that it takes multiple hours to "code" a clean responsive component. @datakick is there any theme, that can be considered as the standard theme for tb? Is it niara? IMO the default styles of the framework should match well with the default theme. Obviously we will strike for some subtle design, that looks on all themes decent.
{$product.reference} or {$product->reference} is probably the thing you are looking for.
💪💪💪 no issues during the update. In my case a I had a bit too much warnings about edited files. But I guess it's working with time stamp right? Cause i had some files, that are 100% equal to original class, but maybe were uploaded again trough FTP. I guess it leads to a warning. Probably almost not possible to change this behaviour.
No problem. That's what tests are for 🙂 Do you have these entries too? I wonder why I have such stuff and others not. I believe some don't have theme, as they use new installs when the new stats module was already introduced...
That's my guess too... Now I have this: I am not at all sure, how I got this modules again. They aren't on my live server and my test server is a copy of it. Are they readded somehow if you change the template? It's probably not a topic that is related to the new core updater, but the "theme <=> module" handling while installing is very unclear to me... Even if I let the config.xml empty in themes it does activate and deactivate all kind of bull****. EDIT: This modules are not even installed. I don't have any such folders in "/modules". But in ps_module there are these modules listed... 🙄 Ui, this shows again how many things can go wrong for noobies. 😕
Ok uninstall and reinstall does fix it. Maybe it's worth to write this in the error message. Cause I got an error also when accessing the BO controller AdminCoreUpdater.
As you say with "this concept", I wonder: are there any other other concepts that might work? Note: for me it's not an option to say: oh you all have to use Bootstrap 5 or so.
That's exactly what I thought too. I am not totally sure, if these default compoments aren't allowed to use any framework. I would just mean that we need to make sure that the libary is loaded. Right, the cleanest would be no framework... ... BUT there is a big question behind it. Do we really want to to build JS components like two range sliders, carousels, accordeon and so on? I highly doubt that's realistic. I haven't found a very good way for this right now. I am myself stuck how I should go. I have some symphaties for AlpineJS, but maybe it's not a good fit for TB. Already the usage of "{" can drive you crazy in smarty files. Any ideas from your side? Edit: the reason why I have some hopes in AlpineJS is actually this: https://alpinejs.dev/patterns
What's the proper "Collation" when creating a database?
wakabayashi replied to Billy's topic in English
I fully agree and like the change! It's quite important these days. Every field that has customer interaction might see emojis. If you like it or not, doesn't matter, customer do use it. I could also imagine that some merchant's want to use it their own. ☺️ -
To be honest, I wouldn't know how my or any other theme could help you in that. You should create a concept of how you want to name your product. In case it's a display thing, you could ofc tweak it a little to your needs. But you could do that already now. Just want to make sure, that you wont wait on anything, that probably won't help you to solve your problem...
@led24ee I am not yet at product listing part. But why do you want to see the code from there? My way of doing it will be more modular than now... @datakick Right now my thing is too raw. But I think it's possible. But in general I believe, that each theme should override this components. I know it's not realistic for old themes, thats why there needs to be a default solution for each component. There are two things planned: Elements: This is simple stuff like buttons, lists or up to a spinner. We just standardize the behaviour of classes. A theme needs to tell, which classes will be applied on a "large call to action button". It's easy in achievable in the conig file. I would state there something like "genzo_button large". A theme that relies on bootstrap will set "btn btn-primary btn-large". A Module developer can now use: <a class="{$css_selector.button_primary} {$css_selector.button_large}">Something</a> It would throw in the right classes depening on the theme used. Components: This is stuff that needs a serious markup. For example: lists, tables, cards and so on. Each theme should then deliver his own tpl file to a component. For example a very simple component (card_default) looks like this: <div class=""> <div class="group block w-full h-auto rounded-lg bg-gray-100 overflow-hidden"> <img src="{$component.image.src}" alt="" class="object-cover pointer-events-none group-hover:opacity-75"> </div> <p class="heading_section mt-2 ml-2">{$component.section}</p> <p class="ml-2 text-sm text-gray-500">{$component.title}</p> </div> A bootstrap theme would deliver a very similair markup with different styles ofc. A module dev can now use something like: $category_1_data = [ 'title' => 'Azul - Uno - Memoarrr', 'section' => 'Familienspiele', 'image' => [ 'src' => '/img/p/bla.jpg', ], 'link' => [ 'url' => '/category/link-1', ], ]; $themeElement = new ThemeHelper(ThemeHelper::COMPONENT_CARD_SIMPLE, $category_1_data, false); return $themeElement->fetchElement(); It will always render a card in the style, that the theme developer initially had in mind. So the design will stay consistent. And obviously the theme developer saves a lot of time as he doesn't need to come up with an own design (that will likely suck on some themes anyway). The card example is of course very simple. There are much more powerful usecases like sliders, modals or whatsever. I am very confident that module devs can reduce their styling work up to 80% or so. Depending on the usecase ofc. The usecase of such component wouldn't stop here. They would also be very powerful on pagebuilder or on shortcode modules.
Thanks for the sources. Tailwind is now very popular so it's not hard to find stuff about it. But I bought TailwindUI, so I have access to really high quality templates. I have coded a very modular way of how a theme should work IMO. In general it adds a Framework in top of TB. Module Developer could save a lot of time and merchants would get a consistent design. But unfortunately it didn't get any real response in "DEV" Channel from TB. Either people are no more around or they are just no interested in creating big changes to an old system. BTW: I am on a webserver. So if somebody would like to see, what I do, I could give you the URL by PN.
Funny then, that they use a thirty bees logo on their homepage ^^
@Billy For me this bootstrap stuff isn't too interesting. As I go with an other CSS Framework called "Tailwindcss". In general most Dev have clear opinion what they want to use. It often leads to little fights inside Dev discussions ^^ I just wanted to say that, not that you create big hopes that anyone here will build something with bootstrap...
@Billy Thanks for the sources. It seems to me, that they have a pretty similair approach when building a theme... But I haven't looked deeply into it. Surely they work with variants too.
@Mark Ok then write me on the Slack Chanel. We can see there, if my module would work for you, too.
