netamismb Posted January 15, 2023 Posted January 15, 2023 Can anybody advise how to migrate a Prestashop 1.6 site to thirtybees?
e-com Posted January 15, 2023 Posted January 15, 2023 There is a free migration module for prestashop 1.6. https://thirtybees.com/migrate-from-prestashop/
nickz Posted January 15, 2023 Posted January 15, 2023 (edited) 5 hours ago, e-com said: There is a free migration module for prestashop 1.6. there might be but the link has no downloadable module available, download it here https://store.thirtybees.com/shop-modules/administration/prestashop-to-thirty-bees-migrator Edited January 15, 2023 by nickz
e-com Posted January 15, 2023 Posted January 15, 2023 53 minutes ago, nickz said: there might be but the link has no downloadable module available, download it here https://store.thirtybees.com/shop-modules/administration/prestashop-to-thirty-bees-migrator Link in the content is correct. https://github.com/thirtybees/psonesixmigrator/releases/tag/2.1.1 You should download the file psonesixmigrator-v2.1.1.zip 1
nickz Posted January 15, 2023 Posted January 15, 2023 4 minutes ago, e-com said: You should download the file psonesixmigrator-v2.1.1.zip I'm not the one needing one but thx
Pedalman Posted February 1, 2023 Posted February 1, 2023 Can I use it to transfer my live TB installation that derives from PS 1.3x times into a fresh TB1.4 or TB1.5 installation?
the.rampage.rado Posted February 1, 2023 Posted February 1, 2023 Are there such shops, still running on PS1.3? You would probably first update to PS1.6 and them migrate using the module above. (using php 7.4) Then remove migrator and update to edge with core updater. Don't forget that TB has core updater and updater module (responsible for the modules updates).
Pedalman Posted February 1, 2023 Posted February 1, 2023 No, no, we just began 10 years ago with PS1.x, and I was one of the first who migrated to TB. I am running now TB1.4 stable, but am tempted to make a clean vanilla installation of TB bleeding edge and a new theme (problably the often mentioned Cisero theme). I then need to migrate my shop data to the new installation (maybe with some 3rd party module I like to continue to use). I know about the great Prestools_Suite but must admit though I am a supporter, I never got really warm with the module.
wakabayashi Posted February 1, 2023 Posted February 1, 2023 2 hours ago, Pedalman said: but am tempted to make a clean vanilla installation of TB What is the advantage of it? You can also just install a new theme 🙂
Pedalman Posted February 1, 2023 Posted February 1, 2023 Well, I am pretty certain that there are lots of old db entries from modules etc we dont use for a long time. But I am just a merchant and think that I should therefore install a fresh installation and migrate shop data (only) to get rid of old entries.
musicmaster Posted February 2, 2023 Posted February 2, 2023 15 hours ago, Pedalman said: Well, I am pretty certain that there are lots of old db entries from modules etc we dont use for a long time. But I am just a merchant and think that I should therefore install a fresh installation and migrate shop data (only) to get rid of old entries. Sounds like you should consider my Copy_shopdata tool. https://www.prestashop.com/forums/topic/445453-copy-shopdata-script-for-upgrading-and-fixing-buggy-shops-by-copying-business-data-and-images/
Pedalman Posted February 2, 2023 Posted February 2, 2023 I will give it a try musicmaster. Thank you for still supporting your great tool! PS: Are you with Panda or Bootstrap5 theme? (pm)
musicmaster Posted February 2, 2023 Posted February 2, 2023 1 hour ago, Pedalman said: Are you with Panda or Bootstrap5 theme? (pm) I am using Panda. No idea about Bootstrap5
