led24ee
Gold member
Everything posted by led24ee
  1. If there is zero answer here then this module isn't attractive. And this means that there is probably no future for this module.
  2. Well. Finally I found latest version of this module. First, there is wrong characters in zip package. When "-v2.2.2" was removed from name then I was able to install this module. After all there are only error 404 pages, whatever button You click "in stock products" or "Show all products" and finally there was 500 error. So I disabled this module at the moment. Still interested how to manage this module to work Decoded exception Source: Missing name in file vendor/smarty/smarty/libs/sysplugins/smarty_template_source.php at line 168
  3. Hi. Is anybody using this module ? When I click on link "Show all" then result is page "best sales". Is this normal ? When I click on "In Stock" then result is error404. Looks like there are modifications in TB after this module was made and now this module is not working properly.
  4. I have made my own translation file. If something is need to change then I edit this file and then upload this file. In this case all modifications are in one place and when you need to start another shop then you already have all. This file contains everything what can be translate; pdf, language, email, modules, etc
  5. According to many, all kind of pop-up things are quite high in the ranking of meaningless inventions of mankind. But it depends what kind of customer you need.
  6. Something like this is already built in. But this is bound to products. Catalog>Products> Quantities>Availability date. I'm not sure this is what You looking.
  7. "They" are my clients. And I'm not developer but some little changes must be done. And YES, This solution is working. Thank You
  8. This put only days on invoice, but they need date. Not 10 days but, due date 25-08-2020.
  9. No. You can set this different for every customer.
  10. Hi I'm from Estonia and here I need Due Date on invoice. Sometimes customer need Invoice before payment and in this case I need to put this Due Date on invoice About max_payment_days. This max_payment_days is in SQL table (customer) and is marked as INT. It is for every customer. Now i try to modify file invoice.summary-tab.tpl (root/pdf) but I don't know how to tell TB that there is need to add INT to DATETIME and then show this as date. I add if condition, that this DUE date is visible only when max_payment_days value is not 0. And this is working. But I don't know how to add this to invoice date. So far I got only errors or unwanted result. File is added. All this is from TB1.1.x At the moment Due Date result is "0" which is definitely not what I need. If i replace both values with numbers, then everything is working. So this summation is working. I'm not sure but i think that because one is DATETIME and another is INT then result is something what TB can't understand. invoice.summary-tab.tpl
  11. Hi. I need modify invoice template (actually this file is invoice.summary-tab.tpl). I need to add one extra field. This is easy. But this field must contain date which is calculated from to variables. One is invoice generated date and this is already existing value. The other on must be invoice date + max_payment_days from table "customer". Can somebody tell me how to construct this ? Thank You
  12. There was similar case. I was able to increase inodes (thanks to my host, this was real quick), webpage "born again" and after this I deleted manually via FTP cache files. This "wasn't" very long process, something 12+ hours. I have no idea how many hundred thousand files there was. But this was just one case. Do not try this urgently repeat. There can be many reason for error500 and this was just one.
  13. Some times error500 is also when there's not enough inodes. This is basically when You have too many files. Look at Your cache folder.
  14. Thanks for no help. After 4 days I found out that there was wrong Schema of URLs. Preferences -> SEO&URL's -> Route to CMS page (and "Route to CMS category"). There was also tag {id}. When this tag is removed everything works.
  15. I got a similar problem. When I create CMS category and put this in HOME category (Home is root category and created category is subcategory) then in BO everything looks good. Now I create some CMS pages and then I put these in earlier created category. Still all is good in BO. Now, when I add these to FO (Block Top Menu) then there is this created category, but when I click on this category then I see pages in HOME category instead of created category. I spend many hours to find out what is wrong, but so far no results. I use t TB1.1.0- Bleeding edge, with all updates. I also have testsite where I'm unable to reproduce this problem. I also compared both sites SQL tables and there are no differences. Any suggestions what can be cause of this ?
  16. led24ee
    Rounding
    I use € at the moment
  17. led24ee
    Rounding
    Looks like it is changed. I just checked and now it removes decimals. There is also possibility to make changes for every currency. Try this too. Maybe this will help.
  18. led24ee
    Rounding
    What version of TB is in use ? In my shop this works exactly what You expect.
  19. You can simply choose are these prices with taxes already or without taxes. In second option this shop will add whatever you choose the tax is and this depends many other things. But this column is the only where you can choose. All others (55 or something) can contain only values that are definitive. Point is that if you put in this CSV prices with VAT but in some reason you choose importing process prices without VAT (or vice versa) then finally you have wrong prices and then you need to wonder what the hell happens.
  20. Well there are some more thing. For example price. You can choose price with VAT and without VAT. It's column 5 if I remember correctly. So be careful before hit that GO button.
  21. Probably missing the whole address (https//www.....). There must be whole address in CSV. If you have testsite then you can test with only one row to understand how this CSV works.
  22. I stuck with the same error. Solution was delete via ftp folder cache/smarty/cache . Maybe someone can explain how this cache works, so I can make changes that are necessary to avoid this kind of problems.
  23. Looks like nobody cares. Partial fix (if this can be called fix) is to always put these filters in order before saving. When You open set of filters next time then this order is "not remembered" and after adding or deleting something you need to make this order again. Really annoying.
  24. Is there any idea how to fix the Block Layered Navigation order for filters ? When I create filter, I can put all available filters in order what I need, but this will not work. The same issue is from PS1.6, but after searching I couldn't get solution. Problem is that all filters are numbered (1, 2, 3 etc) and when You create this order then the result is something like this (21, 18, 8, 52 etc) This order is also presented in SQL database (_layered_filter, column name is "filters") but the result is anyway ordered bu numbers.
