led24ee
Gold member
Everything posted by led24ee
  1. Ok. These module translations inside this gzip are in many places. One of them is also in root/themes and in this case there is prestashop instead of theme name. I try with different theme names.
  2. Yes. I'm trying to translate, but there are many items, what stays still in english. I try to explain. If You export language pack you got file named (languange code).gzip And for me it is really easy to modify items in this file (with 7-zip) and then pack all items again in this file and then import this file.Now there are many sections in this file. translations for emails, for pdf, etc, shortly all, even tabs. And this is fro PS time. Now there are themes catalog in this gzip file. All these translated items begin with the same code. For example module blocksocial is following $_MODULE['<{blocksocial}prestashop>blocksocial_f5d5fbc8332317546cbeb037592e2902'] = 'test'; and this word test is what you see. But. This row contains also theme name. And now I found out that in my case even if the file is in gzip under section themes/niara/modules/blocksocial/translations it still has prestashop instead of niara. Actual row is from fresh install. Is this some kind of error or have I made something wrong ?
  3. Ok. This is complicated. I have no idea yet how this come. But Niara catalog has only 3 folder, while niara has all. Niara has folders : lang, modules,pdf.
  4. Is there any good reason why there is two catalogue in root/themes catalog ? One is niara and then it is also Niara. Can this cause any problems with theme ? edit: as this had nothing to do with the other topic, I moved it here.
  5. Hi. I got the same problem, ERROR 500. I copied some sql tables(including client ones) to new installation. And I run again to this siret and ape problem. I use siret as company registration number, but there is hard coded siret and ape validation in classes/validate.php So this ape and siret validation must be comment out, because this registration number is in different length. After this everything works again.
  6. There is group Visitor and slider (YES/NO) near Cron tasks manager. So visitors are authorized to cron tasks ? What's the point of this ? I have no idea so far.
  7. Hi. Can somebody tell about this ? I'm interested too.
  8. Ok. Let's try. I try to cancel Patreon.
  9. Not supporters ... Let me think .... For example You can put all patreons in supporters file.
  10. led24ee
    Price tax exc
    I'm not sure I understand Your problem. You need price with tax or price without tax ? There are Menu -> Customer -> Groups where You can choose how each group can see prices.
  11. Holy moses, it is working now. I upgraded it long time ago (week or smtg) but I didn't do the reset. Now after reset this token looks much better. Thank You.
  12. If I run this in browser (copy and paste) then everything works. Actual jobs will be done and also cronjobs module shows when was the last time of run and shortly everything looks like one big happy family. Now I have in this same server with this same cPanel one PS 1.6.11.x If I try this cPanel cron with this PS (PS gives another token) then it also works. But in this PS token, there aren't symbols like dot or slash or $. And this is the reason why I believe that cPanel cron is very "selectiv" about this token symbols.
  13. Now I have tried cron with cPanel 80.0.23 but there is always only one result: Invalid token. I have found zero info how to deal with this error. And this is with cPanel only. So this token must contain some symbols not allowed for cPanel. How can I change this token ? Or is there any other solution ? (Plan B for me : change your hosting company)
  14. I don't have this version anymore. But if I remember correctly then my host did also something, this was with PS and TB 1.0. And I tried to ban some IP's with htaccess.
  15. It still is very slow. I experienced something similar when server was misconfigured with .htacces file.
  16. I have only execution time. Actually it's exactly the same time that is in TB cron task section below. This is actual copy " Cron is up and running, last executed few seconds ago (2019-07-27 23:30:09) "
  17. Everything is OK with this cron.
  18. Not local, I have host. But there is possibility ti set up cron task, limit is 5. I tried with these too, but result was not working condition.
  19. None of them.
  20. None of them.
  21. Can somebody tell me HOW to set this cron to work. So far it does nothing.
  22. About modules: tawk.to (V1.1.0), RSS feed (v2.1.0), imageMagick (v1.3.0) are not compatible and can't be installed on TB1.1, but they are by default in module list.
  23. Is this supporters file also updated ?
  24. I remember this. For me solution was module : Contact form anti-spam: reCAPTCHA and blacklist v1.1.4 Also I use this this one too : Blackhole for Bad Bots v1.0.2
  25. The stock quantity didn't remain the same. it doubled, tripled or in some cases even more. Depends on existing quantity.
