Everything posted by zen
I did.. but seems like not in a right way. Now I can see your dev website online 🙂 be careful that it will not be indexed, use a robots.txt file that exclude crawling. Also, on the footer you can put something else in the last column, there is way too much categories showing up there.. maybe just select few ones in non dynamic link... or something else, but that query is useless and repeated on each pages for nothing.
I couldn't find your TB instance What cache did you turn on on back office ? only Smarty cache need to be ON.. all the ones in the bottom can be desactivated or it will make your site slower. For the layered navigation I recommand you to NOT use the default module, specially on such a huge catalog, instead try this one that can be also triggered in search result pages and others pages, it's very efficient and easy to config instead of others I tried. https://www.presteamshop.com/en/prestashop-modules/filter-products-pro.html
I do use the common-service module since years.. it is what it is but it works and support is quite reactive.
please check your order status configuration, there might be something to fix here. Also, do you have any external module installed or any override ? try again de process while overrides and non native modules are desactived.. also turn your cache off and try with different browsers. Best regards.
strange.. do you have any public url to check ?
do you have an url where to see that online ?
the only settings in config.xml file are this : <lazy_load>1</lazy_load> <high_dpi>1</high_dpi> <webp>1</webp>
Panda is compatible with 1.6 version only up to V1.4.5 For PS1.6 and V1.5.3 For TB. that is the V1 of Panda. Now the "up to date" version is V2 now 2.7.0 and it's only gonna work with presta 1.7, it has been a long time that sunny dropped ps 1.6 and TB support.
Yes.. I am also greatfull that TB still exist and people work on it.. but it deserves better, there are so many more people willing to help !
ha OK sorry.. I don't sell any PS 1.7 upgrade, never did never will !! But I was asked to help for a migration website from 1.6 to 1.7, of course I wanted to advise to use TB instead.. but I was not the one in charge and taking decisions, SO I saw the process, from Rocket Classic theme.. that is just a skeleton based on old tech to the last Panda version, it still just look ugly and odd... really there such a Huge gap between Woocommerce themes and Presta.. for TB there is NO real choice, and management of TB seems not interested in buildind something correct to use.... I love TB but being serious I don't think it will lead anywhere if there is nobody in command, looking to improve the system, specially on front office.
sorry, but i don't understand your point, let me says it again : "I installed the last version of PANDA on a PS 1.7, last version, and I was really disapointed by the demos provided for this v2 version, the V1 version for 1.6 and TB was already way too old and not maintened anymore.. but even the 2.0 version (that will never be available for TB) is so outdated that I don't think Panda is going to be a good choice for a theme, that is for PS 1.6, PS 1.7 and TB as well !! so now can you explain me what was your point about ?
I didn't get your point, sorry ...
Nice, as you can customise many things it might a must for many shops !! Since many years I used this module https://www.silbersaiten.de/en/prestashop-modules/133-multiple-features-module.html Is is possible to switch to your code one day from this one ?
I started to modify the modules you need.. give me more time to finish it 🙂
Good that you like it.. I recently installed it for a presta 1.7 and was so disapointed by the demos that looks so old and it was last release.. because for TB and Presta 1.6 the game is over already for Sunny : V2.7.0 For PS1.7, V1.4.5 For PS1.6, V1.5.3 For TB Good luck for updates and bugfixes in the futur ^^
Problem is that Panda is not supported anymore for TB and Presta 1.6.. all new demos and upgrades are for presta 1.7 only now.. and still it starts to look very old compared to new themes availables on envato for example.
Featured products and new products on home page > for that I need to duplicate the default modules and makes some slight changes into them but as the php need to be modified that is why It's better to make a "new" module for the theme and don't break compatibility with older one. At the end of this month I'll get time for that.
how to get it going further ? it could be really nice to make this happen.. I can invest some time for that... what about the TB crew ??
This is awesome.. with not so much dev it can be a real thing to help Thirtybees to remain competitive and attractive for new users and people who wnat to manage their design themselves. What's next ? If that is the new default templating system for TB 1.4 it will just be super great, also it can be outside TB.. maybe payed theme with support and a lot of models, what do you guys think ?
Now I understand your wish, In order to show the slider on all pages, you need to hook it on another hook that is present on every pages like " displayTop " , Hope it works without changin any code from the module.
You can maybe use an address checker that don't allow you to fill incorrect informations, otherwise you can of course block ranges of postal codes to register or use a basic ZIPCODE module that let you set a new transport area.. that will not be covered so they will never access to payment, but can register new account, so you'll have the trace. Is there any payment that succed ?
- 2 replies
- block
- ip block not working
(and 3 more)
Tagged with:
What the support of this module told you ? why do you have to solve it yourself ? Anyway, it's always good to have a maximum of informations in order to help you.
SO i was wrong.. but if it's good now.. datakick you can confirm that it will one day swithc to the new cache control setup ? or advise your customers to do cache refresh on browser CTRL + F5
it will clear what need to be cleared.. for example images jpg are setup for 30 days.. it will not be reloaded if not needed or browser cache emptied
Seems like it's correct now.. you can test it on browser yourself while changing prices like you did before.. maybe make special access product for testing purpose.
