  • 1
Translations not saving
x97wehner
If I try and make a translation change of any sort, it doesn't work. Sometimes it shows in the translation mod UI, and sometimes not. I haven't found a pattern there. The only constant is that after clearing cache and reloading the affected web site pages, the translations are not taking. I check the translation file on the backend and it doesn't have my modifications included either.
Anyone else having the same behavior?
On 5/26/2020 at 8:57 PM, toplakd said:
This is not correct solution for the problem, but removing the one at least don't empty other fields once saving.
For correct solution someone like @datakick or @Traumflug should take a look to see what can be done.
Hi @toplakd. I'm trying your partial solution, but I don't get what should I delete/comment, as @gatasi asked. Which line of the three?
I'm tired of re translating strings every time I have to change something. It should be taken into account, It's always necessary to change some strings in order to adapt the platform. After working like two months I have 264 untranslated strings in spanish, I re entered by hand from a new TB instalations but... they keep cleaning when I change something.
It just erased like 30 strings, after changing one string... It's annoying and time consuming.
Thanks!
Will quote myself:
On 4/3/2020 at 7:08 PM, toplakd said:
Removing Line 1325 in AdminTranslationsController.php solves this issue with emptying other fieldsets that start with same name like address...
$_POST['theme'] or  $_POST['lang'] or  $_POST['type']
Only thing is, that one can not save empty string if that line is removed.
Reading helps. If not working on first try, then I suggest to read the quote again. So many times until it works 😀
Edited by toplakd
3 hours ago, toplakd said:
Will quote myself:
Ha! I swear I read it dozens of times!
Thank you :)
21 hours ago, AndyC said:
Am trying to add another line of text in a translation
ex
1.text
2.text
But when I enter it goes
1.text 2.text
I've tried <br> and <p> it seems to strip them away when entered.
Is there another solutions or is this a bug
It's not a but, you can't edit whatever you want. If you want changes like that you have to make tweaks to your theme/module
