led24ee
Gold member
Everything posted by led24ee
  1. Warning line 1255 in file modules/advancedeucompliance/advancedeucompliance.php [2] count(): Parameter must be an array or an object that implements Countable Could this this error message help solve the problem ?
  2. Yes, I starts. It does something, but I have no idea what. Because the result is that nothing visible is changed. There are no new emails (I have access to this mailbox from mail client also) not in TB or not in this mailbox. But right now mail on TB are different to mails in this mailbox.
  3. With PS this syncronizes all mails from this account to the shop. I got situation when this mailbox outside PS was so big that there wasn't enough place in shop. And then the syncronize process paralyzed whole shop. So I need to go in SQL table to change settings. But with TB this syncronize doesn't do this. I have no idea what syncronization this TB does. I just played with this some days ago.
  4. Same problem here with spam.
  5. Well. At least on carrier is back when ASM is disabled. I go thru all the steps to find out why there is only one carrier back and not all of them. Looks like the sun is shining again (yes, yes, it is almost midnight here) And now all looks good. So at the moment Advanced Stock Management didn't know exactly what he was supposed to do.
  6. Well, finally I removed them all. And then I set up new carrier without any limit. I gave this carrier access to all (all categories, all warehouses, all customer groups, all countries) and still NO carrier. I'm not sure anymore will I continue with TB. If this can be my mistake (whatever I'm doing wrong) or not but this is really frustrating.
  7. Same here. I even have deleted all cookies from browser memory, log off, log on. Nothing changes.
  8. It's Niara with no changes.
  9. If I look in SQL table "carrier" then I see many of them. There is carrier name, weight, depth, tracking page etc. If I look SQL table "warehouse_carrier" then i suppose there are carriers which is active. But both table have also column "carrier_id" and they don't match. So if in table "carrier" is active carrier with id 4, then this is not in table "warehouse_carrier". Is this normal ?
  10. I rechecked, this doesn't help.
  11. I can change name, length, weight, etc in carrier section for each carrier. They are also bounded with products, with clients, with zones, with warehouses. Still nothing.
  12. This doesn't help. Tried this before. I can make changes in carrier section, add, delete, make changes in weight, measures, etc, but in FO there is always no carrier available.
  13. I need help. I lost all carriers in my shop. They are present and set up, but in check out there is constantly "No carriers available". And I can't figure out what is the reason why they are present, but are useless.
  14. I have done this I even don't know how many hundred times. I have tried this long time before this thread. This has zero result for me. Still not visible. Thanks. but there must be something else on my site.
  15. Can You be more specific ? Where exactly You put this ?
  16. led24ee
    AdminScenes
    Is there any plan to "wake up" AdminScene possibility ? It is still existing, but not fully. Or maybe someone is using this possibility ?
  17. There is something weird. For example this one https://docs.thirtybees.com/native-modules/link-block/
  18. This time of year ? There's more than month, when people are waiting for answer. If You ask again then don't think that time will also start again.
  19. This is an old theme. If I remember correctly then it tooks only 10 years for MS Excel to understand that some people use comma instead of dot. But in TB this is still problem. If You are "playing" with CSV then all prices and measures must be with dot. Even if comma is not value or field separator You still cant use this in prices.
  20. Ee .... This is marked as solved. What is solution ? I have TB 1.1.1 with Niara and there is still no checkbox visible. I also couldn't find value 9000 in file (themese/niara/css/) global.css Also this is not solution to mark this box checked like this is in previous post.
  21. There is module for contact form re-capthca, this is only for contact form. For me this was helpful. This is not the same that is already in TB. This is separate module.
  22. There is also CSV possibility, but this is also not easy. Need to check many things, but if it is correct then You can save "tons" of time.
  23. So You got all work again, but still have no idea what was wrong ? You can now try decode this exception. Maybe it gives some useful info.
  24. If I read this title then ...
  25. led24ee
    Nginx
    Well. Looks like at least someone has experience with real life.
