Havouza Posted May 2, 2019 Posted May 2, 2019 Hi After transferring the shop and upgrading to latest version we cant get our import module to import exel sheets anymore. Googled for solutions but nothing help. It is some problem with simpleXml parser in php 7.2it seems So what is the best import plugin for xml or csv?
Adik Posted May 2, 2019 Posted May 2, 2019 (edited) I recommend PrestaShopManager for import. Last week I imported from the old store over 1500 products from the prepared *.xls file (*.csv, *.txt are also supported). In addition over 800MB of product images. Import (VPS Windows 10 IoT->VPS Linux) lasted just over 15 minutes. Unfortunately, this program also has disadvantages, it doesn't support the bottom underline in the product and category urls (like "best_men_shoes_for_summer"). For me, when moving the old store to TB, it was very important for SEO. Of course you can import a csv file with a bottom underline into PhpMyAdmin and run an update SQL query . Edited May 2, 2019 by Adik
Havouza Posted May 2, 2019 Author Posted May 2, 2019 OK thanks. I will not spend that kind of money to add products. There is a lot of different ones in the Prestashop store but you never know if they work with TB
Adik Posted May 2, 2019 Posted May 2, 2019 At the beginning of the import game, I bought this module: https://addons.prestashop.com/en/data-import-export/19091-product-catalog-csv-excel-import.html Works fine with ThirtyBees but it does not support national language characters
Havouza Posted May 2, 2019 Author Posted May 2, 2019 What language is a problem? We have used BA importer without any problem but when I moved the shop to a new server it stopped working. All reguirement are OK but I get a xml parser error. If it is a module problem or a TB problem I dont know
Adik Posted May 2, 2019 Posted May 2, 2019 Problem is with coding during import, instead of polish diacritics we have a bushes. You may need to save the encoding format in the first line of the *.csv file. I use Ron'sEditor and he has this option. The best csv editor I've used so far. https://www.ronsplace.eu/Products/RonsEditor
Beeta Posted May 6, 2019 Posted May 6, 2019 I'm using GetDataKick to import XML. And now that I learned it I like it. It helps also to do some mass updates, and exports too. The dev is active here (@datakick) and he gives great support.
Pedalman Posted May 7, 2019 Posted May 7, 2019 Easy to use for all I need to do in TB is: " StoreCommander " They do not explictitly support TB at the moment but I use it since half a decade and with TB since 2 years and never had an issue. Support is fast. You find on their webpage a documentation about CSV im/export. You can buy software for a year and do not have to extend subscription. It is pretty solid and does not need constant upadates. Storecommander next to Datakick and Prestatools should speed up article maintanance enourmously.
zen Posted May 7, 2019 Posted May 7, 2019 On my opinion, I would not recommand too much the software Store Commander for many reasons I rather use "prestashop manager" wich work good with TB, certified. I have a long relationship with SC, his founder and the Support.. so I speak by experience, but everybody is free to decide whatever he wants for his buisness tools. Anyway, for products import I always use the standart csv native import tool, if you have problems on your php version, why not import them on a local computer or another platform for that it's fresh shop installed and working for XML parsing.. you'll always be able to inject them on database afterward or just copy the database from the dev version filled with new products, that is solution without using a software or payed service.
Havouza Posted May 7, 2019 Author Posted May 7, 2019 The latest version of BA importer works flawless. Just have to keep away from TB 1.0.8 or developer version, at least for now. For our needsits perfect and resonable priced
movieseals Posted May 8, 2019 Posted May 8, 2019 11 hours ago, Havouza said: The latest version of BA importer works flawless. Just have to keep away from TB 1.0.8 or developer version, at least for now. For our needsits perfect and resonable priced Which version are they at at the moment? Sorry to hear it still does not work with the dev version. 😞
haylau Posted May 8, 2019 Posted May 8, 2019 (edited) On 5/6/2019 at 10:03 AM, FooLab said: I'm using GetDataKick to import XML. And now that I learned it I like it. It helps also to do some mass updates, and exports too. The dev is active here (@datakick) and he gives great support. @datakick - your module says it will work with CSV files soon. Can you say when? Looking to import stock levels and prices only (in thirtybees and prestashop) and another prestashop instance that would also have lots of combinations Edited May 8, 2019 by haylau 1
datakick Posted May 13, 2019 Posted May 13, 2019 On 5/8/2019 at 3:20 PM, haylau said: @datakick - your module says it will work with CSV files soon. Can you say when? Looking to import stock levels and prices only (in thirtybees and prestashop) and another prestashop instance that would also have lots of combinations CSV import functionality was put on hold for the time being. Unfortunately it's too much effort for (>2week of work) for little reward, as most merchants are quite happy with build-in csv import.
Beeta Posted May 13, 2019 Posted May 13, 2019 On 5/8/2019 at 3:20 PM, haylau said: @datakick - your module says it will work with CSV files soon. Can you say when? If you are in a VPS you can convert CSV to XML
haylau Posted May 13, 2019 Posted May 13, 2019 5 hours ago, datakick said: most merchants are quite happy with build-in csv import. Yeh - can;t be automated though. No worries. We are using store manager, just a little clunky but works fine 1
haylau Posted May 13, 2019 Posted May 13, 2019 5 hours ago, FooLab said: If you are in a VPS you can convert CSV to XML We are VPS but would not have a clue where to start with that. Not a problem we can stick with Store Manager
Billy Posted May 13, 2019 Posted May 13, 2019 (edited) 5 hours ago, FooLab said: If you are in a VPS you can convert CSV to XML @FooLabHow would one go about that? Thanks Edited May 13, 2019 by Script-Fu
Beeta Posted May 15, 2019 Posted May 15, 2019 On 5/13/2019 at 4:16 PM, Script-Fu said: @FooLabHow would one go about that? Thanks you need to loop in the csv file and for every loop write the xml structure a resource here: https://askubuntu.com/a/581681
danwarrior Posted July 4, 2019 Posted July 4, 2019 Hi, guys! I'm thinking about get Store Manager for a new big project, can you share your experiences? One of the most important things for me is feature massive edition... Thanks!
zen Posted July 4, 2019 Posted July 4, 2019 You can test it for free, and then make your own opinion. I think it's the best way to know by yourself.
danwarrior Posted July 4, 2019 Posted July 4, 2019 Just now, zen said: You can test it for free, and then make your own opinion. I think it's the best way to know by yourself. The thing is I have Mac and is being so difficult mount the virtual machine, so I can't try it yet 🙂
Pedalman Posted July 4, 2019 Posted July 4, 2019 SC is its money more than worth! You can trust me. But TB is officially not supported. This morning I was in contact with there support. Which is great btw too. But first question. "Mr. Boris are still running TB?" .... This question is related to the way how SC handles image import. You can greatly utilize SC for this, too. But I still do not know if it makes use of PS/TB imagecontroller or uses its own, which it has. Question is if you are forced to use SC's controller or if you an set it off an bipass it so you can use modules like Wepb and Kraken.io or ImageMagick. Else, I can tell you: Buy the module. It is its money really worth. Boris 1
