oliiiix Posted September 12, 2019 Share Posted September 12, 2019 Dear All The TB reCaptcha module doesn't work for me at all. First of all: after installation, clearing the cache didn't get rid of the 500 error message. I had to delete the whole cache folder and re upload the one from the TB Zip file. Then, configuration seems to work without problems. The captcha is displayed on the contact form as well, but it doesn't matter as I can do everything without clicking on the captcha at all. So it doesn't stop me from sending contact messages even though I haven't checked the captcha checkbox. It's there, but it's not working. I can send as many contact messages without ever touching the captcha to confirm me not being a robot. Anyone else having the same issues? I have configured the module completely and set it to appear everywhere it can be configured to appear. I also have overrides enabled etc under performance. Luckily I can continue with ei captcha which I used for prestashop which is working as it should 😉 Here's the link for everyone else who's having trouble: https://github.com/nenes25/eicaptcha You'll have to use the latest version as previous versions were not working when JS was disabled! All the best, Oli 1 Link to comment Share on other sites More sharing options...
datakick Posted September 12, 2019 Share Posted September 12, 2019 recaptcha module works fine as long as 'Login attempts' settings is set to 0. https://github.com/thirtybees/nocaptcharecaptcha/issues/5 1 Link to comment Share on other sites More sharing options...
rubben1985 Posted January 21, 2020 Share Posted January 21, 2020 Hi @datakick It doesn't work for me either. login attempts is set to 0.... this is my formulary. It appears but you can send the message without clicking in the recaptcha https://www.lesielle.com/int/es/contacto Any ideas? I am using bleeding edge and Panda template (compatible with TB) Link to comment Share on other sites More sharing options...
datakick Posted January 21, 2020 Share Posted January 21, 2020 Can you check if the module's overrides are installed correctly? Link to comment Share on other sites More sharing options...
rubben1985 Posted January 21, 2020 Share Posted January 21, 2020 1 hour ago, datakick said: Can you check if the module's overrides are installed correctly? How Can I do that? Link to comment Share on other sites More sharing options...
wakabayashi Posted January 21, 2020 Share Posted January 21, 2020 Probably search for: \override\controllers\front\ContactController.php 1 Link to comment Share on other sites More sharing options...
rubben1985 Posted January 21, 2020 Share Posted January 21, 2020 Ah, so Yes, I see that file with date modification from today so it has to be from the module installation. Link to comment Share on other sites More sharing options...
wakabayashi Posted January 21, 2020 Share Posted January 21, 2020 Wtf. I was sure it its working in my store. Just tested too and the captcha is not needed 😂 Link to comment Share on other sites More sharing options...
rubben1985 Posted January 21, 2020 Share Posted January 21, 2020 5 minutes ago, wakabayashi said: Wtf. I was sure it its working in my store. Just tested too and the captcha is not needed 😂 😂 Link to comment Share on other sites More sharing options...
datakick Posted January 21, 2020 Share Posted January 21, 2020 oi, there's a new bug in core 🙂 When NoCaptchaRecaptcha module is installed, the call to Module::isEnabled('NoCaptchaRecaptcha') returns false, while call Module::isEnabled('nocaptcharecaptcha') returns expected true. I'll fix this in the core. Until then, you edit override file (\override\controllers\front\ContactController.php) and replace all occurrence of Module::isEnabled('NoCaptchaRecaptcha') with Module::isEnabled('nocaptcharecaptcha') 3 Link to comment Share on other sites More sharing options...
wakabayashi Posted January 21, 2020 Share Posted January 21, 2020 Oh I was just trying to solve it too ^^ Thanks for the solution! I can confirm, that it works again! Link to comment Share on other sites More sharing options...
rubben1985 Posted January 21, 2020 Share Posted January 21, 2020 I also confirm it is working! Just to know how it works... If I am using bleeding edge and you correct the core, should I also change (revert) again this override file, or no need to touch anything because bleeding edge update core but also modify (revert) this file to its original/correct state? I hope I explained myself clearly 😅 Link to comment Share on other sites More sharing options...
wakabayashi Posted January 21, 2020 Share Posted January 21, 2020 I believe, it doesn't matter at all. I guess, he will fix the core, so that lower/uppercase won't matter anymore. Next time when you update the module, the override will probably be replaced, but I am not 100% sure about it. Link to comment Share on other sites More sharing options...
datakick Posted January 21, 2020 Share Posted January 21, 2020 4 minutes ago, rubben1985 said: I also confirm it is working! Just to know how it works... If I am using bleeding edge and you correct the core, should I also change (revert) again this override file, or no need to touch anything because bleeding edge update core but also modify (revert) this file to its original/correct state? I hope I explained myself clearly 😅 CoreUpdater will fix code in core only, it will not touch your module. But, in this case, you won't have to do anything. This issue will just be fixed 'twice' 🙂 1 Link to comment Share on other sites More sharing options...
Traumflug Posted January 22, 2020 Share Posted January 22, 2020 On 1/21/2020 at 6:12 PM, datakick said: I'll fix this in the core. Not sure whether this is a good idea. NoCaptchaRecaptcha and nocaptcharecaptcha are two distinct modules, one can have both installed. Any attempt to deviate from the name of the directory on disk might well lead to unexpected behavior in other places. Link to comment Share on other sites More sharing options...
Acer Posted February 4, 2020 Share Posted February 4, 2020 (edited) So I encountered the same problem now with TB 1.1.0 and latest "nocaptcharecaptcha" module... I can confirm that Datakick's fix above works. For those of us with an existing override, this post will help.Module Update Request please: Can Datakick's fix please be incorporated into the module and pushed as update?https://github.com/thirtybees/nocaptcharecaptcha/issues/5 New users / developers will continue to experience this problem until it's been patched. Also, I'm sure (from what I've seen in this thread) that there are merchants that think this is working when it's actually not. Edited February 4, 2020 by Theo Link to comment Share on other sites More sharing options...
datakick Posted February 4, 2020 Share Posted February 4, 2020 38 minutes ago, Theo said: Module Update Request please: Can Datakick's fix please be incorporated into the module and pushed as update?https://github.com/thirtybees/nocaptcharecaptcha/issues/5 No, it can't. The issue you are referencing is about something very different, it has nothing to do with this new problem on bleeding edge. I've filed a new issue to track this new problem https://github.com/thirtybees/nocaptcharecaptcha/issues/8 Note that while we can fix this in the module, we need to fix the core as well 1 Link to comment Share on other sites More sharing options...
x97wehner Posted February 22, 2020 Share Posted February 22, 2020 Just has this same issue. Spam to my contact us form, a new one each minute. Found this feed and updated code to the lower case variant as mentioned above and the spam stopped. Link to comment Share on other sites More sharing options...
datakick Posted February 22, 2020 Share Posted February 22, 2020 Version 1.1.2 has been released few days ago with the fixes. No need to manually apply the fix, simply download the latest version 2 Link to comment Share on other sites More sharing options...
Joint Systems Posted May 20, 2021 Share Posted May 20, 2021 The TB recaptcha works on most of our 31 TB stores but have had a real problem with the others. What happens is the recaptcha box does not show up to check on the index page. When the customer attempts to create an account or even sign into an existing account he gets an error message that the recaptcha is incorrect. Tried resetting the app, uninstalling and reinstalling, neither worked. We then deleted the module folder from the store that did not work and then copied the module folder from the site that was working, changed the keys to the right domain and still didn't work. Took Oliiix's advice and installed eicaptcha 4.17 which is the last upgrade for prestashop versions below 1.7. So far it has worked on all the problem sites. Good Stuff Oliix:) Link to comment Share on other sites More sharing options...
