  1. Thanks for your update! Let's say no deal will be achieved (which is very likely). What happens then? Will we see something in the beginning of 2021? Or will we have to wait another few months till the fork is leading anywhere?
  2. I for myself would almost never need to know which products are inside the order on the overview. It seems to me, that you have a special process when handling orders. But in general it's not super hard to add a custom column, if you ask an expierenced dev to do it. There are hooks which can be used. This module does it for carrier: https://github.com/thirtybees/orderlistcarriers
  3. Oh thanks for this hint. Now I understand why a tool (added with composer) made problems 😮 It was also this classname...
  4. Advanced Stock Management does it...
  5. Of course with every week going on with no deal, the trust in this project is sinking. From my side I just added a PR to github. Thats all I can do for now. I saw that others @Mediacom87 and @zen are also still adding PRs. So there is still some chance. But seriously @Messenger Bee I expect something real till end of the year. There may be shop owners, who can use old software and still make a solid business. But there are also other merchants in a highly competitve surrounding. I doubt that the first group is large enough and I also doubt this group will get bigger. In my country and my niche I can find a new competitor almost every month. That's my reality. Of course the shop system is not the only key to success, but an important one.
  6. @datakick Is there any known issue with the installer?
  7. I am not sure, but there exits a cleaner module for tb/ps. After a clean installation there are always a few orders. With the cleaner module you can remove it. Maybe it works for you too. Or is this the module you are talking about?
  8. Why would you want to do that? As far as I know this is just for stats of ps/tb owner.
  9. I believe you have to select "hidden Hooks" and then it could be "dashboardData". Not totally sure tough.
  10. Btw this is an official module and I have never seen it before. Is this module up do date? When do you get this message exactly?
  11. Please enable debug mode and post the full error message.
  12. Well it's not completly obvious to me, which date_to should be filtered. But to get rid off the message replace in the WHERE-Line `date_to` with a.`date_to`
  13. Probably very easy to solve, but you need to switch on debug_mode and post the error from there...
  14. In Plesk you just add the domain as a new website and then point it to the folder, where thirtybees is installed.
  15. I am not sure if he have got the multistore technically correct. For example check the table "ps_product_shop". You will see that every product has it's own row per shop. But yeah it's good, if you rethink everything multiple times. Its tempting to start multiple stores, but it has it's drawback...
  16. Hm you can easily select the store(s) for each category. IMO there is no "mothershop".
  17. Your question is very unclear for me. Haven't you already solved it with your response? But yeah it's for sure possible. But keep in mind that multistore brings some issues up and is more complex to handle. I am a multistore user for years, but we plan to go down to single store.
  18. But it is fixed like that? This button is very easy clicked by mistake 🙂 It happened to multiple merchants before 🙂
  19. Oh one moment... you never tested this after switching? When we switched the cart system, all users had to use "password forgotten" feature...
  20. I have just sign up - worked. Logout - worked. Login - worked. So I guess it's only about old customers. :S
  21. What is your url? Have you installed any module recently? Do you have any cronjobs going on?
  22. 🤣🤣 Seriously: on the top right corner there is a button for demo mode. I guess, this is activated...
  23. Thanks for the link! Improving stats is for sure nothing bad ☺️ I haven't tested this module. Maybe somebody can tell, if it works with tb as well 🤗
  24. Yeah, if you also don't know exactly why this is important for your customers, I would deactivate it. The more features, the more confusion pointes for your customer.
  25. Hello Luke Nice store. I like it! I am a bit surprised that you use two different fonts. You could also consider to hire a designer on Fiverr or so, which can draw category images in the same style. What is the QR-Code Feature about?
