  1. Yeah, but I can't blame PhpStorm. I just duplicated tools.js long ago and made very little changes. Since then the core file changed a lot. I think that's a trouble many theme designer are facing.
  2. Damn! I had an tools.js file in my theme. It was basically an old PS File. This made all the errors :( No I deleted this file and it works again...
  3. Do you have any idea, why this error appear? Are you using 1.0.3? I believe tools.js file is making the trouble :S
  4. Probably this problem did not come from the new currencies, but from the upgrade (1.0.1 => 1.0.3), I made some days ago!? // @since 1.0.2 Media::addJsDef(['currencyModes' => Currency::getModes()]);
  5. Hello there Is anybody of you using multiple currencies? I just added a few new curriences (Euro, Dollar and Pounds). Since then I can't create any orders in backoffice. It doesn't find the products trough Ajax. Firefox Console: TypeError: window.currencyModes is undefined Any idea? Please tell me if you have same issue...
  6. @bzndk oh ok. Thanks for the info! Will have to see, how it works on different machines...
  7. Module is on! Where can I see how much CPU it takes in Windows 10? In Task Manager I can only find CPU Usage for Chrome in general :S
  8. @jnje said in Multi-Shop Struktur: Wo jeder Shop primär seine eigene Produkte hat davon ca. 20% - 25% der Produkte sich teilen. Das ist zwar theoretisch möglich, aber du wirst über einige Bugs stolpern. Dann nicht verzweifeln, einfach melden! Hier bei thirty beees kümmert man sich noch um gemeldete Bugs :)
  9. Could find a solution. This does the trick: $helper->table = 'genzo_link'; $helper->id = $id_genzo_link; $helper->identifier = 'id_genzo_link';
  10. In my helperForm I want to use the inbuilt shop selector. The select tree shows up, but I can't manage to set up the tplvars correctly. Strangely it doesn't matter what I put under 'name' (blabla). The checkboxes always have the name "checkBoxShopAssoconfiguration". ``` if (Shop::isFeatureActive()) { $inputs[] = array( 'type' => 'shop', 'label' => $this->l('Shop association:'), 'name' => 'blabla', ); } $fields_form = array( 'form' => array( 'legend' => array( 'title' => ('Add Link'), 'icon' => 'icon-cogs' ), 'input' => $inputs, 'submit' => array( 'title' => ('Update'), 'class' => 'btn btn-default pull-right' ) ) ); $helper = new HelperForm(); $helper->submit_action = 'saveLink'; $helper->default_form_language = $this->context->language->id; $helper->currentIndex = $this->context->link->getAdminLink('AdminModules', false) . '&configure=' . $this->name .'&module_name=' . $this->name; $helper->token = Tools::getAdminTokenLite('AdminModules'); $vars['blabla'][3] = 0; $helper->tpl_vars = array( 'fields_value' => $vars, 'languages' => $this->context->controller->getLanguages(), 'id_language' => $this->context->language->id, ); ``` How do I need to set up tpl_vars, so that only the shops with an entry are selected? Let's say I have 3 shops and only in the first two shops is an entry. I thought, I have to do like this: $vars['blabla'][1] = 1; $vars['blabla'][2] = 1; $vars['blabla'][3] = 0; That's the way I do for lang fields, but this is not working. It selects always all 3 shops. Thanks for your help! If something is unclear, please tell me where you need better explanation.
  11. The cleaner way would be to change AdminOrdersController.php around line 495...
  12. Dirty try: delete all email templates or rename them. I think the tmeplate is intransit.html and intransit.txt PS: I agree that this should be optional...
  13. Yes I can confirm, that an e-mail is sent, when you add the tracking number. We use this feature :) love it :yum:
  14. I am quite sure that the module will be compatible for 1.0.x. I can't see any reason, why it shouldn't be. Michael was working on it, but then he was little bit distracted with some personal stuff (non tb related). But now he is coding again :thumbsup_tone1: My tip: while you are wating for ES module, prepare for christmas sales ;) :D
  15. Oh you need to use different comment styles... ``` // one line comment in php /* multline comment in css and php */ {* multine comment in smarty (tpl-files) *} ``` You will find a lot of examples in google :)
  16. Oh I am dumb. You can fix it. Add this to your global.css div#tl_popupCL1 { z-index: 100!important; } Yes always make backups. When I change files. I always start with comments like: // Changes Alwayspaws ... That way you will find your fixes very fast in your files...
  17. If the update overrides this files. Yeah then you will have to re do it. I have no idea, why this hover is working so badly. Strangely i can see a z-index=0 :S but you can't change this :( Another fix is needed.
  18. Maybe this is a module. Do you have a module installed, which is named like "footer links" or something like this?
  19. Yes. I thought so, but no idea how it looks like :)
  20. @alwayspaws you are welcome. We all want to have a lot of visitors. Buyers are even better :D But ecommerce is a hard game.
  21. I would clearly put this in the footer. But not sure if this is best practice or just the way I like it...
  22. @alwayspaws the close tag comes later... When you see your page it contains different tpl files. header.tpl and footer.tpl are always included.
  23. Where you want the logo to show up? In the footer?
  24. With every modern browser you inspect the html code of every website. You should just look for the links. Let's take your signature in this forum: As you can see, the link has a rel="nofollow". This means for google: oh I shouldn't follow this links. In other words this link won't give you a lot of linkpower. Maybe even no power. Are such nofollow links worthless? No. They still bring users trough direct clicks.
