colorful-ant
  1. ich hatte ebenfalls das gleiche problem. mir fehlte im text der link zur widerrufsbelehrung. im modul aeuc habe ich die widerrufsbelehrung zur agb hinzugfügt/aktiviert und schon war die checkbox sichtbar.
  2. @AndyC alternatively you can also try the (for example) free stripe module from prestashop (for ps version 1.6). if you haven't tried it yet.
  3. maybe that will help you to change it for you
  4. The only thing I know on the quick is that text can be added. panda theme editor -> header/mobile header -> scroll down to mobile header
  5. @datakick is it possible: - remove the discount coupon from the shopping cart - display of available discount coupons to integrate this into the module?
  6. @AndyC tb stripe doesn't work for you? just to be sure: - you have also entered the live access data in the shop - is the server / hosting suitable for this (the requirements) - the payment settings in the shop are activated for stripe - etc ... EDIT: i have been using datakick's chex module in a shop for a few weeks now. it is not yet perfect for all my shops, but stripe and paypal also work very well here
  7. i use the second -> standard account with address i had problems with paypal. 1. there were orders without address 2. there was an order with an old address - customer did not correct his new address etc..... and I sell download products -> for this I need the billing address for a correct invoice
  8. settings under modules services -> payment all ok?
  9. here you can correct words. For example, someone is looking for a word and has a spelling mistake. As a result, the product can not be found. Here you can create a list of misspellings (or more - manipulate would not be the correct word for it now), so that the right products are displayed in the search. It's best to test it yourself. And at the end of the adjustment page (weight) make your desired selection - search only after 3 characters begin or after 4 characters, etc. I try it as an example false - correct bloose - blouse blues - blouse ........ etc
  10. I'm not 100% sure. For the Panda template, the module is more for the design. The search function itself comes from the shop core. Example, are all products in the index?
  11. i´m not sure if it will helps for you tb standard modul -> prferences -> search here you can change some settings
  12. zusatz, das mit den bearbeitungskosten (als zusatzoption) habe ich noch nie probiert, mit TB und PS - keine ahnung, evtl kannst du das auf ner demo testen wie das funktioniert und es evtl weiter hilft
  13. theoretisch habe ich auch das problem, aber ich lebe mit den kleinen umständen, es kommt zum glück äußerst selten vor, dass dies bei mir passiert. wie es rechtlich aussieht, weiß ich leider nicht, da habe ich nicht weiter geprüft. therotisch und praktisch kannst du in den versandeinstellungen einiges tun - hier ein beispiel mit versandkostenfrei ab 80 € dreh den spieß etwas rum, erhöhe die versandkosten oder so, wenn es ok sein sollte, damit der verlust geringer ausfällt. oder erstelle einen zusätzlichen versanddienst dafür .... die versandkosteninfo (cms) etc nicht vergessen anzupassen 😉
  14. Personally, I do not like this version / format with a comma. I only use csv with semicolon separated fields. with Excell or e.g. OpenOffice I have a better overview and can also find an error faster, if there should be problems during the import and that does not happen often.
  15. plesk - server software/tool/manager .... alternatives: confixx/ispconfig/cpanel ...........
  16. backoffice - you find it here (example): php.ini i use plesk and i can change the php settings for example
  17. thanks - now I understand the problem
  18. i´m not sure mail-address have no correct domain for example [email protected] - have you tried with the last signs (.com or another) ?
  19. vom händlerbund gab es jetzt auch noch eine verständlichere erklärung, wer interesse hat: https://www.onlinehaendler-news.de/e-recht/rechtsfragen/131796-fuenf-haeufigsten-fragen-eugh-cookie-urteil
  20. is your cart module installed? have you a similar problem see this topic?
  21. regenerate your htaccess and try again
  22. ok, danke - so macht die sache natürlich mehr sinn
  23. ob es einen einfluß auf den tb core hat weiß ich nicht, ich vermute eher nicht. ich muß mir das selber wahrscheinlich noch ein paaar mal alles durchlesen etc. seit ein paar wochen habe ich jetzt theoretisch nur den shop-coockie. google analytics habe ich rausgenommen, weil manche probleme mit ghostery für mozilla usw. mit dem login hatten. nach jetzigem stand werde ich bei dem cookie-banner module ich vermutlich eine andere lösung finden müssen. so wie ich das jetzt verstehe, ist das als opt-out auch nicht mehr richtig innerhalb der eu, obwohl dieser shop-cookie ja ein notwendiger cookie ist. oder erst mal drüber schlafen und dann weiter sehen. das urteil selbst hab ich mir bislang nicht angesehen. zur umsetzung insgesamt wird es ja bestimmt eine gewisse frist geben.
  24. EuGH: Cookies nur noch mit Einwilligung hier ein link dazu https://www.onlinehaendler-news.de/e-recht/aktuelle-urteile/131776-eugh-cookies-nur-noch-mit-einwilligung
  25. Thank you for your answer. Yes, I'm talking about a module. See my first text with the link. There you get to the "LD + JSON" module of TB. Meta tags - hmmmm partially, this is mainly about the Google rich snippets. If the product.tpl file and product-list.tpl are correct setup - it is from my point of view only partially ok. The header.tpl etc and what google and other search engines are allowed to see should also be correct. For example, here's his releases: https://github.com/thirtybees/jsonmodule/releases or from TB-store https://store.thirtybees.com/shop-modules/front-office/json-module In between, I have already considered that module to disable. I have to take a closer look at that before. I do not know what to describe in more detail? I think my sentences in the first comment are sufficient. Also deposited with pictures. There you can see where more warnings are in the review of the structured data.
