zen
Everything posted by zen
  1. What did you setup in the STEP 3 of carrier configuration ? put 0 for each field.. if it's not the case already
  2. moving from one solution to another is always a risk, it has to be really well done. Good that things are finally moving in the right direction.. do you still have errors that can be fixed ? I personnaly don't use any of SEO module or Meta Tag manager, it's not needed if your template is well done, remember to be really up to date with the Google Rules, they change sometimes and nobody tells you ^^
  3. https://addons.prestashop.com/en/457-social-login-connect here are some too : https://www.knowband.com/fr/prestashop-free-social-login on the forum, same module : https://www.prestashop.com/forums/topic/512924-free-module-facebook-google-social-login-and-15-in-1-module-knowband/ etc... https://www.prestashop.com/forums/topic/494491-free-module-facebook-login-registration/
  4. to "polish" it you'll need to dive into webdesign and UX, make a nice logo, take care of small details.. it takes a huge amount of time and dedication , endless job in fact ! Don't you use bank transfer in your website too as a first choice for your customers ? Also, to speed all the process of registering, you can add a social media plugin for login, it will fill all the infos like mailing adress in one click for your customers. One page checkout process is also a good option in your case to simplify ordering process. Customers need to trust your shop, all theses details increase it or make them run... having a direct contact with the seller is a good way to bypass the website trustable quality, but it increase a lot your job as much as if it works good in a close future, you won't be able to take care of all these orders yourself.. then having a proper website is helping a LOT, and from there you can force almost everybody to order online only. Best regards and good luck 🙂
  5. OK, good to know. I remember your shop now, I said it was not in production because it looks like you don't want user to really order on it, it's seems "under work", not finished yet and not polished enough to give trust in that platform. I understand why now, it's just the back office you need 🙂
  6. OK Mark, I see the point in the better way now. But How could customers prefers to pay by bank transfer ? this is the less used payment method in Europe for normal users, only Pro / B2B still use it, may I ask you what do you sell online ?
  7. I wonder why you do such a thing, if customers don't buy on your eshop, you just need an accounting software isn't it ? Using an ecommerce website to manage all this seems like it's looking for trouble and complications.. in fact you can even use excel only.
  8. yes, sorry.. and that was the answer under the one i quoted... oups
  9. why 63 and not 64 then ?
  10. Well, in my experience with some shops having a lot of uploaded files it never was a problem.. 32 caracters is a lot !! It makes (26+10+12)^32 = 6.305501e+53 different names possible. I guess going to 64 will make it readable even more for complex filenames, but 128 is really too much, way too much, and maybe will break compatibility on some servers settings quote : "I would like to clarify, that linux has a 255 bytes limit per filename, not 255 characters. This is a significant difference and if you use e.g. UTF-8 encoding, you may end up with filenames of 100 characters max." https://unix.stackexchange.com/questions/32795/what-is-the-maximum-allowed-filename-and-folder-size-with-ecryptfs SO, OK to upgrade to 64 caracters maximum... but no more is needed I think
  11. I am maybe not answering your question for real... but I can tell you that each category can have only one parent, products can have also only one categorie 'by default' BUT can be assigned to as much categories as you want. The breadcrumb when viewing a product will show the default category path of this product.
  12. Very interesting thread, let's start to upgrade Niara with better mobile experience ! I am agree to spend time for that and make a super mobile friendly theme 🙂
  13. Il n'y aurait pas un plugin sur ta version de Firefox qui empêcherait certains scripts d'être chargés ou fonctionnels ?
  14. Not for sure but I can have a look, please give credentials if you want Also you can roll back your online website to TB 1.0.8 version, and try to sort it out on a dev version.
  15. zen
    Broken images
    I gave you my help in PV but you canceled it.. so what to do ?
  16. zen
    Broken images
    How to help somebody who knows better way..i Wonder ?..... Lucky that that your website is not in production for real
  17. zen
    Broken images
    Mark: "Ok so I need to know what the settings should be " Zen: The settings are all yours.. it depends on the result you want in your front office.
  18. zen
    Broken images
    seems like something is broken ... the url for the pic seems not correct : "/product/" should not be there or it is your root directory on the server for this website.. I doubt this. but the images path are good : https://product.solutions.org.nz/img/p/1/7/9/179.jpg this image on the exemple you provide does not exist : 194, so the repport you have when regenerate thumbnails is logic. But still now, your images settings are not correct.
  19. zen
    Broken images
    egos are boring.
  20. zen
    Broken images
    Nice... AND usefull !
  21. I suggest a solution, here is the pull request : https://github.com/thirtybees/thirtybees/pull/1060
  22. zen
    Broken images
    I do believe that everything can be fix.. otherwize I don't know what you think I believe... I just want to help this user on his particular case, that should not happen, but before fixing the core, this user needs specific help in his settings, and I'll provide this care if he accepts. I know images are harcoded, that's where the matter starts, Also there is way too much images sizes for produits... only 3 or 4 will be enough and will help to maintain an image directory light.
  23. zen
    Broken images
    If you want, I can fix that for you with BO Access, as u like 🙂
  24. zen
    Broken images
    Now you did this, your theme request this image : https://product.solutions.org.nz/194-community-theme-default_cart_default/remote-car-alarm-with-central-locking-and-engine-disable.jpg then you need this image setting : community-theme-default_cart_default, what size is it ? I don't know but it's should be square I guess. Also on the same page you need also this image : https://product.solutions.org.nz/98-home/3000-lumen-headlight-with-sensor-and-red-light.jpg and that is "home"
  25. zen
    Broken images
    datakick was right : you need "home" as a default image size, but it's not available on your settings, so it's not created, therefore you can't show them in front office. You need to edit the images config, and delete all images sizes wich are not used and estup one for "home" and others missing.. then regenerate thumbnails !
