  1. @Occam Datakick clearly explained the issue with the foreach loop. If there are other issues, we need concrete bug reports otherwise we can't fix it.
  2. What are you talking about? :S About the screenshots. Can we check the html code somewhere? To me this looks like a css or html issue.
  3. Well I bet this module was developped for 1.7. I could look into it, if I have the ftp and BO access.
  4. This error doesn't make sense to me. It says unexpected " but there is no " at all. Probably we would have to see more, to solve it.
  5. Try instead of 'title' => $this->trans('Save', array(), 'Admin.Actions') the following: 'title' => $this->l('Save')
  6. @Pedalman Yes that is the intention of the module. @Briljander I am working on a new module for products tags. But I am not yet sure, if and how I will release it. @danwarrior I will send you the module right now. Would be cool, if you can test it a little.
  7. Ok I have just internally released v.1.1.0. This version fixes the issue of adding a new language and has a much cleaner way of using object model. If you are patreon, I can send you the new version. Just write here in the thread.
  8. Is somebody using this module on his shop? I probably have to release 1.1 soon, as I found an issue, when adding a new language to your store. So if you found any issue or have other improvement suggestion, please place it here 🙂
  9. Is there any issue with the sum of ratings? I just got a review. It's the first of the product. Obiviously it should be 4 stars (as showed also in BO) but the overall Rating is 5 stars: https://www.spielezar.ch/brettspiele/architekten-des-westfrankenreichs
  10. We dont have any payments then. Its basically bank transfer.
  11. Normally when a customer orders by phone we use a [email protected]. So just a fake email. If the customer really wants his email, to be stored, we use a manual password. Same as you, but we tell the customer that he should use the "Forget password" to set a new one...
  12. Same here: Every page I tried loads slow.
  13. I would guess you can just download the from: https://github.com/thirtybees/niara/releases
  14. Can it by a comma instead of point issue?
  15. Thanks for your post! Thats exactly how I think about it, too!
  16. You have good speed on your site 🙂
  17. I don't know if I have already reported. But there is an issue with criteria that don't apply to all products/categories. In my case I always apply them to categories. But when I edit such a criteria, the categories aren't selected. In addition it says something like: "apply to no product" in the overview.
  18. Yeah I got this. That's why I want to implement the expiration feature. But I really don't get the point having part "expiration". Either it makes no difference at all (when customer doesn't order anymore and lose all it's coins). Or the user loses a part of his coins (in your way) and none coins (in my way). But I as a customer would be totally angry if your case comes in. If I place a new order at your store and still lose some of my coins I would think: Ar they kidding me? I am still buying stuff there, but still delete my coins :S In addition: how likely is this case? As far as I understand a loyalty points system almost always works like this: You order something and collect a few points. You use them on your next order and the thing is done. Doesn't 99% of the orders work like this? Probably the module doesn't show it. But I get your point. There is nothing wrong in adding this number somewhere 😉
  19. Yes it's working now...
  20. Tbh: that would be quite a huge rewrite/extension. And I really don't believe it's user friendly. If somebody is interested to code this solution, I am open for merging something. But I won't code this "feature" myself. When I am looking again deeper at the module I will think, if I can implement a solution for customer returns.
  21. Well maybe it's a cache issue. When I visit the link from above, there isn't "checked" in the html source code.
  22. Yes that should work. Does it?
  23. Please search in your tpl files for "check_autobid" and then post the code of the tpl.
  24. I can't find the correct place... Either it's still the wrong tpl or it isn't a checkbox at all. A link to an example could help.
  25. I dont think that is the right tpl. It should be have something like: input type="checkbox" Edit: yes the second one looks better.
