Silver member
  1. I dont know about datakicks module. Probably he will respond here too. If you really wanna add this fastly you could use the following script. But please make a backup before. $ids_add_accessory = [3862, 3861]; $query = new DbQuery(); $query->select('id_product'); $query->from('product'); $ids_product = array_column(Db::getInstance()->ExecuteS($query), 'id_product'); $inserts = array(); foreach ($ids_product as $id_product) { foreach ($ids_add_accessory as $id_add_accessory) { if ($id_product!=$id_add_accessory) { $inserts[] = array( 'id_product_1' => $id_product, 'id_product_2' => $id_add_accessory, ); } } } Db::getInstance()->insert('accessory', $inserts, false, true, 2); You basically change the values in $ids_add_accessory. If you want to just add this tags to some products (instead of all), you could also work with $ids_product manually. Example: $ids_add_accessory = [1,2,3] and $ids_product = [100,101] This means that products with id 100 and 101 get the accessoires 1, 2 and 3.
  2. Well it depends, which modules you are using... Have you looked at the new html block module? About the stores. There is a controller in your menu called "AdminStores". I don't know how the menu point is called, but it is inside "Preferences". In general it's easier to answer such question, if there is one topic per problem. For example you say you are using module xy and it creates problem z.
  3. I believe lesley has already talked to this dev multiple times...
  4. Yep I have missed that with xampp. Still: like that I can't help. If it were my store I would compare the two version. Check if the html structure is exact the same. If yes I would check css.
  5. It's not about you fixing the bug or something. But how should I understand the problem, if you don't share a link to the issue. I don't have transformer theme...
  6. @Occam Datakick clearly explained the issue with the foreach loop. If there are other issues, we need concrete bug reports otherwise we can't fix it.
  7. What are you talking about? :S About the screenshots. Can we check the html code somewhere? To me this looks like a css or html issue.
  8. Well I bet this module was developped for 1.7. I could look into it, if I have the ftp and BO access.
  9. This error doesn't make sense to me. It says unexpected " but there is no " at all. Probably we would have to see more, to solve it.
  10. Try instead of 'title' => $this->trans('Save', array(), 'Admin.Actions') the following: 'title' => $this->l('Save')
  11. @Pedalman Yes that is the intention of the module. @Briljander I am working on a new module for products tags. But I am not yet sure, if and how I will release it. @danwarrior I will send you the module right now. Would be cool, if you can test it a little.
  12. Ok I have just internally released v.1.1.0. This version fixes the issue of adding a new language and has a much cleaner way of using object model. If you are patreon, I can send you the new version. Just write here in the thread.
  13. Is somebody using this module on his shop? I probably have to release 1.1 soon, as I found an issue, when adding a new language to your store. So if you found any issue or have other improvement suggestion, please place it here 🙂
  14. Is there any issue with the sum of ratings? I just got a review. It's the first of the product. Obiviously it should be 4 stars (as showed also in BO) but the overall Rating is 5 stars: https://www.spielezar.ch/brettspiele/architekten-des-westfrankenreichs
  15. We dont have any payments then. Its basically bank transfer.
  16. Normally when a customer orders by phone we use a [email protected]. So just a fake email. If the customer really wants his email, to be stored, we use a manual password. Same as you, but we tell the customer that he should use the "Forget password" to set a new one...
  17. Same here: Every page I tried loads slow.
  18. I would guess you can just download the from: https://github.com/thirtybees/niara/releases
  19. Can it by a comma instead of point issue?
  20. Thanks for your post! Thats exactly how I think about it, too!
  21. You have good speed on your site 🙂
  22. I don't know if I have already reported. But there is an issue with criteria that don't apply to all products/categories. In my case I always apply them to categories. But when I edit such a criteria, the categories aren't selected. In addition it says something like: "apply to no product" in the overview.
  23. Yeah I got this. That's why I want to implement the expiration feature. But I really don't get the point having part "expiration". Either it makes no difference at all (when customer doesn't order anymore and lose all it's coins). Or the user loses a part of his coins (in your way) and none coins (in my way). But I as a customer would be totally angry if your case comes in. If I place a new order at your store and still lose some of my coins I would think: Ar they kidding me? I am still buying stuff there, but still delete my coins :S In addition: how likely is this case? As far as I understand a loyalty points system almost always works like this: You order something and collect a few points. You use them on your next order and the thing is done. Doesn't 99% of the orders work like this? Probably the module doesn't show it. But I get your point. There is nothing wrong in adding this number somewhere 😉
  24. Yes it's working now...
  25. Tbh: that would be quite a huge rewrite/extension. And I really don't believe it's user friendly. If somebody is interested to code this solution, I am open for merging something. But I won't code this "feature" myself. When I am looking again deeper at the module I will think, if I can implement a solution for customer returns.
